Not sure if this is the right place but after searching and reading the other posts on this subject, I still didn’t find the answer.
I’m getting the SSL handshake error on my Raspi 3B and the companion app however I’m also noticing that a bunch of my “internet connected” integrations are failing now as well including Google, Govee, Plex, and a couple others. I assume the issue is related.
Below is the log for the Google Integration. Definitely connection related but not sure why or what changed.
Logger: homeassistant.config_entries
Source: components/nest/__init__.py:213
First occurred: March 4, 2023 at 11:08:03 PM (1 occurrences)
Last logged: March 4, 2023 at 11:08:03 PM
Error setting up entry Configuration.yaml for nest
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 174, in _new_conn
conn = connection.create_connection(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/connection.py", line 72, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File "/usr/local/lib/python3.10/socket.py", line 955, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 703, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 386, in _make_request
self._validate_conn(conn)
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 1042, in _validate_conn
conn.connect()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 358, in connect
self.sock = conn = self._new_conn()
File "/usr/local/lib/python3.10/site-packages/urllib3/connection.py", line 186, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x5e4798f8>: Failed to establish a new connection: [Errno -3] Try again
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 489, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.10/site-packages/urllib3/connectionpool.py", line 787, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.10/site-packages/urllib3/util/retry.py", line 592, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='www.googleapis.com', port=443): Max retries exceeded with url: /oauth2/v4/token (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x5e4798f8>: Failed to establish a new connection: [Errno -3] Try again'))
File "/usr/local/lib/python3.10/site-packages/google/auth/transport/requests.py", line 193, in __call__
response = self.session.request(
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 587, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/sessions.py", line 701, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.10/site-packages/requests/adapters.py", line 565, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='www.googleapis.com', port=443): Max retries exceeded with url: /oauth2/v4/token (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x5e4798f8>: Failed to establish a new connection: [Errno -3] Try again'))
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 383, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/nest/__init__.py", line 213, in async_setup_entry
await subscriber.start_async()
File "/usr/local/lib/python3.10/site-packages/google_nest_sdm/google_nest_subscriber.py", line 415, in start_async
await self._subscriber_factory.async_new_subscriber(
File "/usr/local/lib/python3.10/site-packages/google_nest_sdm/google_nest_subscriber.py", line 260, in async_new_subscriber
return await loop.run_in_executor(
File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.10/site-packages/google_nest_sdm/google_nest_subscriber.py", line 283, in _new_subscriber
creds = self._refresh_creds(creds)
File "/usr/local/lib/python3.10/site-packages/google_nest_sdm/google_nest_subscriber.py", line 271, in _refresh_creds
creds.refresh(Request())
File "/usr/local/lib/python3.10/site-packages/google/oauth2/credentials.py", line 335, in refresh
) = reauth.refresh_grant(
File "/usr/local/lib/python3.10/site-packages/google/oauth2/reauth.py", line 322, in refresh_grant
response_status_ok, response_data, retryable_error = _client._token_endpoint_request_no_throw(
File "/usr/local/lib/python3.10/site-packages/google/oauth2/_client.py", line 209, in _token_endpoint_request_no_throw
request_succeeded, response_data, retryable_error = _perform_request()
File "/usr/local/lib/python3.10/site-packages/google/oauth2/_client.py", line 185, in _perform_request
response = request(
File "/usr/local/lib/python3.10/site-packages/google/auth/transport/requests.py", line 199, in __call__
six.raise_from(new_exc, caught_exc)
File "<string>", line 3, in raise_from
google.auth.exceptions.TransportError: HTTPSConnectionPool(host='www.googleapis.com', port=443): Max retries exceeded with url: /oauth2/v4/token (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x5e4798f8>: Failed to establish a new connection: [Errno -3] Try again'))
