I’ve installed home assistant on a system that’s just updated (and rebooted after the update). Home assistant keeps restarting with this error:
Jan 10 16:07:52 craptop systemd[1]: Started Home assistant.
Jan 10 16:07:52 craptop (hass)[15570]: home-assistant.service: Unable to locate executable '/var/lib/hass/.venv/bin/hass': Permission denied
Jan 10 16:07:52 craptop (hass)[15570]: home-assistant.service: Failed at step EXEC spawning /var/lib/hass/.venv/bin/hass: Permission denied
Jan 10 16:07:52 craptop systemd[1]: home-assistant.service: Main process exited, code=exited, status=203/EXEC
/var/lib/hass/.venv/bin/hass does exist, and is owned by nobody. After a Chmod to 777, the error doesn’t change:
# ls -la /var/lib/hass/.venv/bin/
total 34212
drwxr-xr-x 1 nobody nobody 192 Jan 10 14:55 .
drwxr-xr-x 1 nobody nobody 76 Jan 10 14:53 ..
-rwxr-xr-x 1 nobody nobody 221 Jan 10 14:54 envs
-rwxrwxrwx 1 nobody nobody 235 Jan 10 14:55 hass
-rwxr-xr-x 1 nobody nobody 218 Jan 10 14:54 httpx
-rwxr-xr-x 1 nobody nobody 1709 Jan 10 14:54 jp.py
-rwxr-xr-x 1 nobody nobody 225 Jan 10 14:54 jws
-rwxr-xr-x 1 nobody nobody 240 Jan 10 14:54 normalizer
-rwxr-xr-x 1 nobody nobody 235 Jan 10 14:53 pip
-rwxr-xr-x 1 nobody nobody 235 Jan 10 14:53 pip3
-rwxr-xr-x 1 nobody nobody 235 Jan 10 14:53 pip3.13
drwxr-xr-x 1 nobody nobody 36 Jan 10 14:54 __pycache__
lrwxrwxrwx 1 nobody nobody 15 Jan 10 14:53 python -> /usr/bin/python
lrwxrwxrwx 1 nobody nobody 6 Jan 10 14:53 python3 -> python
lrwxrwxrwx 1 nobody nobody 6 Jan 10 14:53 python3.13 -> python
-rwxr-xr-x 1 nobody nobody 229 Jan 10 14:54 slugify
-rwxr-xr-x 1 nobody nobody 34608320 Jan 10 14:54 uv
-rwxr-xr-x 1 nobody nobody 362872 Jan 10 14:54 uvx
-rwxr-xr-x 1 nobody nobody 222 Jan 10 14:53 wheel
Terminals output:
# pacman -S home-assistant
resolving dependencies...
looking for conflicting packages...
Packages (3) blas-3.12.0-5 lapack-3.12.0-5 home-assistant-1:2024.12.5-1
Total Download Size: 15.53 MiB
Total Installed Size: 22.71 MiB
:: Proceed with installation? [Y/n]
:: Retrieving packages...
home-assistant-1... 12.7 MiB 4.58 MiB/s 00:03 [######################] 100%
lapack-3.12.0-5-... 2.6 MiB 7.78 MiB/s 00:00 [######################] 100%
blas-3.12.0-5-x86_64 230.1 KiB 4.78 MiB/s 00:00 [######################] 100%
Total (3/3) 15.5 MiB 4.84 MiB/s 00:03 [######################] 100%
(3/3) checking keys in keyring [######################] 100%
(3/3) checking package integrity [######################] 100%
(3/3) loading package files [######################] 100%
(3/3) checking for file conflicts [######################] 100%
(3/3) checking available disk space [######################] 100%
:: Processing package changes...
(1/3) installing blas [######################] 100%
(2/3) installing lapack [######################] 100%
(3/3) installing home-assistant [######################] 100%
:: Running post-transaction hooks...
(1/2) Reloading system manager configuration...
(2/2) Arming ConditionNeedsUpdate...
[root@craptop cedric]# systemctl start home-assistant
# journalctl -fu home-assistant
Jan 10 16:07:45 craptop systemd[1]: Starting Home assistant...
Jan 10 16:07:49 craptop python[15553]: Requirement already satisfied: wheel in /var/lib/hass/.venv/lib/python3.13/site-packages (0.45.1)
Jan 10 16:07:50 craptop python[15562]: Processing /usr/share/home-assistant/homeassistant-2024.12.5-py3-none-any.whl
Jan 10 16:07:50 craptop python[15562]: Requirement already satisfied: aiodns==3.2.0 in /var/lib/hass/.venv/lib/python3.13/site-packages (from homeassistant==2024.12.5) (3.2.0)
Jan 10 16:07:50 craptop python[15562]: Requirement already satisfied: aiohasupervisor==0.2.1 in /var/lib/hass/.venv/lib/python3.13/site-packages (from homeassistant==2024.12.5) (0.2.1)
Jan 10 16:07:50 craptop python[15562]: Requirement already satisfied: aiohttp==3.11.11 in /var/lib/hass/.venv/lib/python3.13/site-packages (from homeassistant==2024.12.5) (3.11.11)
<snip>
Jan 10 16:07:51 craptop python[15562]: Requirement already satisfied: uart-devices>=0.1.0 in /var/lib/hass/.venv/lib/python3.13/site-packages (from bluetooth-adapters>=0.16.1->habluetooth>=3.0->home-assistant-bluetooth==1.13.0->homeassistant==2024.12.5) (0.1.0)
Jan 10 16:07:51 craptop python[15562]: Requirement already satisfied: usb-devices>=0.4.5 in /var/lib/hass/.venv/lib/python3.13/site-packages (from bluetooth-adapters>=0.16.1->habluetooth>=3.0->home-assistant-bluetooth==1.13.0->homeassistant==2024.12.5) (0.4.5)
Jan 10 16:07:51 craptop python[15562]: Requirement already satisfied: PyRIC>=0.1.6.3 in /var/lib/hass/.venv/lib/python3.13/site-packages (from bluetooth-auto-recovery>=1.2.3->habluetooth>=3.0->home-assistant-bluetooth==1.13.0->homeassistant==2024.12.5) (0.1.6.3)
Jan 10 16:07:51 craptop python[15562]: Requirement already satisfied: btsocket>=0.2.0 in /var/lib/hass/.venv/lib/python3.13/site-packages (from bluetooth-auto-recovery>=1.2.3->habluetooth>=3.0->home-assistant-bluetooth==1.13.0->homeassistant==2024.12.5) (0.3.0)
Jan 10 16:07:51 craptop python[15562]: Requirement already satisfied: botocore<1.36.0,>=1.35.96 in /var/lib/hass/.venv/lib/python3.13/site-packages (from boto3>=1.10.49->pycognito==2024.5.1->hass-nabucasa==0.86.0->homeassistant==2024.12.5) (1.35.96)
Jan 10 16:07:51 craptop python[15562]: Requirement already satisfied: jmespath<2.0.0,>=0.7.1 in /var/lib/hass/.venv/lib/python3.13/site-packages (from boto3>=1.10.49->pycognito==2024.5.1->hass-nabucasa==0.86.0->homeassistant==2024.12.5) (1.0.1)
Jan 10 16:07:51 craptop python[15562]: Requirement already satisfied: s3transfer<0.11.0,>=0.10.0 in /var/lib/hass/.venv/lib/python3.13/site-packages (from boto3>=1.10.49->pycognito==2024.5.1->hass-nabucasa==0.86.0->homeassistant==2024.12.5) (0.10.4)
Jan 10 16:07:51 craptop python[15562]: Requirement already satisfied: python-dateutil<3.0.0,>=2.1 in /var/lib/hass/.venv/lib/python3.13/site-packages (from botocore<1.36.0,>=1.35.96->boto3>=1.10.49->pycognito==2024.5.1->hass-nabucasa==0.86.0->homeassistant==2024.12.5) (2.9.0.post0)
Jan 10 16:07:51 craptop python[15562]: Requirement already satisfied: six>=1.5 in /var/lib/hass/.venv/lib/python3.13/site-packages (from python-dateutil<3.0.0,>=2.1->botocore<1.36.0,>=1.35.96->boto3>=1.10.49->pycognito==2024.5.1->hass-nabucasa==0.86.0->homeassistant==2024.12.5) (1.17.0)
Jan 10 16:07:51 craptop python[15562]: homeassistant is already installed with the same version as the provided wheel. Use --force-reinstall to force an installation of the wheel.
Versions:
# uname -a
Linux craptop 6.12.8-arch1-1 #1 SMP PREEMPT_DYNAMIC Thu, 02 Jan 2025 22:52:26 +0000 x86_64 GNU/Linux
# pacman -Q home-assistant
home-assistant 1:2024.12.5-1
