First time for me.
Restarted Home Assistant as a result of changes to a lovelace dashboard and now it doesn’t start anymore. With this I mean I can’t access the system via the browser <IP>:8123
I’m running the latest versions (OS, Supervisor, Core) on a VirtualBox (6.1.16) running on Fedora 31.
I can access /config via Samba. This is what’s in /config/home-assistant.log
2021-04-12 23:26:05 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/scripts.yaml contains duplicate key "service". Check lines 7 and 11
2021-04-12 23:26:05 WARNING (SyncWorker_0) [homeassistant.util.yaml.loader] YAML file /config/scripts.yaml contains duplicate key "data". Check lines 8 and 12
2021-04-12 23:26:05 WARNING (MainThread) [homeassistant.loader] You are using a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-04-12 23:26:05 WARNING (MainThread) [homeassistant.loader] You are using a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-04-12 23:26:06 WARNING (MainThread) [homeassistant.components.http] The 'base_url' option near /config/configuration.yaml:85 is deprecated, please remove it from your configuration
2021-04-12 23:26:06 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2021-04-12 23:26:16 WARNING (MainThread) [homeassistant.setup] Setup of recorder is taking over 10 seconds.
2021-04-12 23:26:20 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=108 from 2021-04-12 13:24:31.709169)
2021-04-12 23:26:21 WARNING (MainThread) [homeassistant.loader] You are using a custom integration wyzesense which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-04-12 23:26:21 WARNING (MainThread) [homeassistant.loader] No 'version' key in the manifest file for custom integration 'wyzesense'. As of Home Assistant 2021.6, this integration will no longer be loaded. Please report this to the maintainer of 'wyzesense'
2021-04-12 23:26:21 WARNING (MainThread) [homeassistant.loader] You are using a custom integration energyeasy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-04-12 23:26:21 WARNING (MainThread) [homeassistant.loader] No 'version' key in the manifest file for custom integration 'energyeasy'. As of Home Assistant 2021.6, this integration will no longer be loaded. Please report this to the maintainer of 'energyeasy'
2021-04-12 23:26:24 ERROR (MainThread) [elkm1_lib.elk] Invalid message '00C2'
File "/usr/local/lib/python3.8/site-packages/elkm1_lib/elk.py", line 139, in _got_data
self._message_decode.decode(data)
File "/usr/local/lib/python3.8/site-packages/elkm1_lib/message.py", line 79, in decode
raise ValueError(error_msg)
ValueError: Incorrect message length
2021-04-12 23:26:24 ERROR (MainThread) [homeassistant.components.sensor] Error while setting up energyeasy platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 205, in _async_setup_platform
await asyncio.shield(task)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/config/custom_components/energyeasy/sensor.py", line 156, in setup_platform
sensors.append(EnergyEasySensor(energyeasy_data, variable, name))
File "/config/custom_components/energyeasy/sensor.py", line 180, in __init__
self._state = round(self.energyeasy_data.data[self.type], 2)
TypeError: type NoneType doesn't define __round__ method
What seems concerning is the message whether home-assistant_v2.db
has been shutdown properly. It’s size is 616MB and counting even though I no longer have access. There are some integrations (wyzesense, energyeasy) which don’t seem to be supported anymore but this shouldn’t stop a system from booting up.
I have access to HA from the VirtualBox terminal. Logged in via ‘root’ and did a ha> core check
which threw an error. Tried a ha> core rebuild
which finished successful, core check still with errors.
I have reported earlier that the system was progressively getting slower - something hard to believe given I’m running 20GB Ram on a Dell OptiPlex 950. So it may be I have run out of resources somewhere (log file(s) etc.)
I’m tapping in the dark here. What’s the best way to recover this?
