I don know where to search anymore. Hopfully someone can give me the tip to discover whatś going on.
THis is my situation: I run Home assistant in docker on a NUC (I5) for year now and it worked really great. However. Since a month or twoo, I get timeouts when I access it from outside.
II have my own domain and forward it to my local server. It runs Traefik as a reverse procy, offloading SSL. I use it for both home assistant and Nextcloud and that is still stable available from outside where Home Assistant fails often. Sometimes it suddenly works. Also Uptime robot keeps informing me several times a day Home Assistant to be down or up again.
The NUC has a I5 and 4G of memory, running docker on Ubuntu server LTS.
Whe I run Developer tools network monitoring in a browser, it seems that often something goes wrong with a token?
Here is my stack setup using Home Assistant, ZwaveJS and MariaDB
# Home assistant, ZwaveJS and MariaDB
version: '2'
networks:
lan:
external: true
services:
zwavejs:
image: zwavejs/zwavejs2mqtt:latest
container_name: zwavejs
restart: unless-stopped
devices:
- "/dev/ttyACM0"
environment:
- PGID=1000
- PUID=998
- TZ=Europe/Amsterdam
volumes:
- /opt/ha/zwave:/usr/src/app/store
networks:
- lan
ports:
- 3000:3000
- 8091:8091
home-asstant:
image: homeassistant/home-assistant:latest
container_name: homeAssistant
network_mode: "host"
environment:
- PGID=1000
- PUID=998
depends_on:
- mariadb
- zwavejs
volumes:
- /etc/localtime:/etc/localtime:ro
- /opt/ha/hass:/config
mariadb:
image: mariadb:10.1
container_name: mariadb
environment:
- PGID=1000
- PUID=998
networks:
- lan
ports:
- 3306:3306
volumes:
- /opt/ha/db:/var/lib/mysql
