Quite a while ago i made my self i little Home assistant glow using a esp8266 and a generic photo sensor
So for a while ive been having issues with spikes in energy consumption, ive tried every filter combination i could find up until now that i found out what was causing the spikes
We have a gas stove and by shear luck i was watching the logs when a family member ignited a flame
Low and behold i saw the same high spikes i was seeing (9600w)
The esp itself doesnt seem to be the problem as it can only pickup the spikes when the dupont jumper wire used to connect the photosensor is connected to the sense pin and someone uses the stove.
