Hi there, I am seeing some weird readings on my HomeAssistant Glow
Normally it’s sitting at around 30KW and every couple of seconds it drops to 4K and then back to 30K
I’m hoping someone else has had something like that and fixed it
any pointers would be great.
The code I have put on the ESP32
# Home Assistant Glow
# Read your electricity meter by means of the pulse LED on your
# meter, useful if you do not have a serial port (P1).
substitutions:
slug: electricity-monitor
description: "Measure your energy consumption with the pulse LED on your smart meter"
time_timezone: "Africa/Johannesburg"
wifi_ssid: !secret wifi_ssid
wifi_password: !secret wifi_password
wifi_ap_password: "esphome-${slug}"
pulse_pin: GPIO12
status_led: GPIO5
# imp/kWh rate ⬇ #
pulse_rate: '1000'
api:
reboot_timeout: 30min
services:
- service: reset_total_energy
then:
- button.press:
captive_portal: ~
logger:
baud_rate: 0
ota:
safe_mode: true
reboot_timeout: 10min
num_attempts: 5
button:
- platform: restart
name: "Reset - Total Energy"
on_press:
- pulse_meter.set_total_pulses:
value: 0
time:
- platform: homeassistant
timezone: "${time_timezone}"
on_time_sync:
- component.update: sensor_uptime_timestamp
- platform: sntp
servers:
- !secret ntp_server
- platform: uptime
device_class: "timestamp"
accuracy_decimals: 0
update_interval: never
lambda: |-
static float timestamp = (
id(time_homeassistant).utcnow().timestamp - id(sensor_uptime).state
return timestamp;
name: "${name} Wi-Fi Signal Percentage"
icon: "mdi:wifi"
unit_of_measurement: "%"
lambda: |-
if (id(sensor_wifi_signal).state) {
if (id(sensor_wifi_signal).state <= -100 ) {
return 0;
} else if (id(sensor_wifi_signal).state >= -50) {
return 100;
} else {
return 2 * (id(sensor_wifi_signal).state + 100);
} else {
return NAN;
- platform: wifi_signal
name: "${name} Wi-Fi Signal"
update_interval: 300s
on_value:
- component.update: sensor_wifi_signal_percentage
# Pulse meter
- platform: pulse_meter
name: '${name} - Power Consumption'
unit_of_measurement: 'W'
state_class: measurement
device_class: power
icon: mdi:flash-outline
pin: ${pulse_pin}
# internal_filter: 100ms
on_value:
then:
- light.turn_on:
- delay: 0.5s
- light.turn_off:
filters:
# multiply value = (60 / imp value) * 1000
# - multiply: 60
- lambda: return x * ((60.0 / ${pulse_rate}) * 1000.0);
total:
name: '${name} - Total Energy'
unit_of_measurement: 'kWh'
icon: mdi:circle-slice-3
state_class: total_increasing
device_class: energy
accuracy_decimals: 3
filters:
# multiply value = 1 / imp value
# - multiply: 0.001
- lambda: return x * (1.0 / ${pulse_rate});
# Total day usage
- platform: total_daily_energy
name: "${name} - Daily Energy"
power_id: sensor_energy_pulse_meter
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
text_sensor:
- platform: wifi_info
ip_address:
name: "${name} IP Address"
ssid:
name: "${name} Connected SSID"
bssid:
name: "${name} Connected BSSID"
wifi:
ssid: "${wifi_ssid}"
password: "${wifi_password}"
ap:
ssid: "${name}"
password: "${wifi_ap_password}"
esphome:
comment: "${description}"
build_path: "./.build/${slug}/"
esp32:
board: nodemcu-32s
uart:
rx_pin: RX
baud_rate: 4800
binary_sensor:
- platform: status
output:
# - platform: gpio
# pin: GPIO5
# id: output_blue
- platform: gpio
pin: GPIO2
- platform: gpio
pin: GPIO4
light:
- platform: binary
internal: true
output: output_red
status_led:
pin:
number: GPIO5
web_server:
port: 80
local: true
crazy. I just noticed this happened after I just updated ESPHome the other day. It’s nice to have it fixed by the filter, but does anyone know why this happened. I have run without filter since I set it up few years ago and have run without issues then all of sudden this. That’s why I wonder if this filter is now needed after some updates perhaps ? but again you had your issue here in June way before the update I just did. I seek answers
