I have recently received Home Assistant Green and now would like to add ebeco Connect floor heating sensors to it. I am already using those using the Ebeco app separately but would like to use them via HA.
I found this but GitHub - joggs/home_assistant_ebeco: Integration for Ebeco thermostats but is there a way to install it to Home Assistant Green? What would I need to do.
Install
- Download the Ebeco app and create an account.
- Make sure you can manage the thermostat via the Ebeco app
- Install this Ebeco component via HACS or copy the files to the custom_components folder in Home Assistant config.
- Restart Home Assistant and add this integration
- Login with the same user/pass as you’ve used for the Ebeco app
