Home Assistant Green Brand New not working
Hi all
Very new to this. Ordered my home assistant green. Followed the instruction, getting error message “Error Installing Home Assistant”.
NSURLErrorDomain -1004
Can someone please help on what to do next? I have the error log but can’t post with so many links. Thanks Manish
Welcome! How are you attempting to access HA Green (Windows Pc, Phone etc…)? That error is a network error.
Using iPhone App
you don’t have “Limit IP Address Tracking” turned on for your iphone do you?
settings->wifi-> choose your home wifi->scroll till you see it.
Try reaching Home Assistant in a browser using the ip address of your Green with :8123 at the end. So something like http://192.168.1.50:8123
You should be able to find what IP address it has been assigned from your router.
To expand on @cogneato suggestion, you can open CMD and ping homeassistant.local -4
You’ll get an IP and results if it’s replying to the ping.
or enter http://homeassistant.local:8123/ in your browser to connect.
Tried turning that off. No success. Any other guesses I can try? I was really looking forward to use home assistant?
Tried accessing it from local browser. No luck. Who can I contact to help me with this. I just spent $150+ buying this and it’s not working first step. Very disappointed.
OK, so to start with - we need to know how it’s connected to your network. Is it a normal network, or do you have a VLan setup? Have you verified in the router that it has actually given the Home Assistant Green an IP address?
Hi Andrew
Yes I have logged into the router and have a confirmed ip address of 192.168.0.129. I have tried putting this manually in iOS app and it shows me the error code
Could not connect to the server.
Error Code:
As a Google search shows, NSURLError’s are caused by SSL issues. When you put the IP address into the app - you should have put:
http://192.168.0.129:8123
Out of the box Home Assistant does NOT use https
This can occur when a host name resolves, but the host is down or may not be accepting connections on a certain port.
NSURLErrorCannotConnectToHost | Apple Developer Documentation
Don’t use the app. Continue trying to reach HA in a browser from a device which is on the same network. What exactly are you entering in the address bar of your browser?
Where were you seeing the error about installing Home Assistant?
Do you have a screenshot of your browser attempt that includes the address you are using?
If you need, you can factory reset it using an SD card and the process described in the documentation: Resetting the device – Home Assistant Green
This process requires that the Green has access to the internet to download the parts needed to complete setup.
what was a resulution of this issue from Manish_Sharma above?
How it was resolved? I have completly the same issues.
Thanks for reply.
BR
This happened to me, and I fixed it using the following instructions to reset the device
This was a brand new device purchased from Amazon yesterday. I had confirmed the device was responding with RST to any connection attempts on port 8123.
I’m frustrated. I had some serious issues with HA - ZHA quit working, then all my automations vanished and new ones wouldn’t save (and blueprints wouldn’t load) so I factory reset Home Assistant Green, held down the button until is tuned on solid, then waited a while. According to my router, it then pulled down about 2.6 GB of data, but when I go to connect I get a site refused to connect 192.168.50.62 refused to connect. The app gives a little more detail "Could not connect to the server. NSURLErrorDomain code -1004 URL http://192.168.50.62/dashboard-condo/0
.Any help is appreciated. I can’t live without HA.
