Home assistant green installation
Excited to get my HA green and impressed it is self installing and updating, and now I get the following errors
It keeps looping like this. Any ideas? All the other posts do not include this version 2025.1.2
Thank you!
Hmmm. That’s an odd one, have you by an chance tried unplugging and rebooting the Green that way?
If its still occurring, are you connecting it to the internet in any special way (firewalls, filtering, blocking, etc)
Finally got to to a factory reset with SD card and it is getting stuck in the same loop about downloading 2025.1.2 it has no firewalls, just plugged into the router directly.
Hmm, what’s your DNS settings? Per this thread, someone else fixed it by changing their DNS settings at the router level to Google DNS (8.8.8.8). Double checking another thread makes me think DNS (like most networking issues) is at fault.
Are you able to check the DNS settings in your router? If you’re comfortable with the command line, you should be able to follow a few of the commands listed in that thread such as
ha net info
For that command, you’re gonna need to plug the Green into a Monitor & keyboard. If you could provide a screenshot/image of what that outputs that would go a long way.
So DnS is now set to Google’s. Rebooted and then it loaded but only 2024.12.0 and keeps trying to update to 2024.12.3 to no avail. Just times out within the HA app on iOS. No keyboard. Can use currently, so cannot do that as of now
When its updating, is it giving any different error code or just the same “headers” error that you originally posted?
Sorry, in the middle of moving houses! Here is a screenshot when trying to update supervisor. Any ideas? Seems like core is current version.
Ok. So same error about headers.
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:245
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 01:41:18 (6 occurrences)
Last logged: 23:34:29
[281472770973776] Unexpected exception
[281472630370320] Unexpected exception
[281472631316560] Unexpected exception
[281472614326352] Unexpected exception
[281472631310224] Unexpected exception
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 262, in async_install
    await self.coordinator.supervisor_client.supervisor.update()
  File "/usr/local/lib/python3.13/site-packages/aiohasupervisor/supervisor.py", line 43, in update
    await self._client.post(
    ...<3 lines>...
  File "/usr/local/lib/python3.13/site-packages/aiohasupervisor/client.py", line 182, in post
    return await self._request(
    ...<7 lines>...
  File "/usr/local/lib/python3.13/site-packages/aiohasupervisor/client.py", line 129, in _request
    await self._raise_on_status(response)
  File "/usr/local/lib/python3.13/site-packages/aiohasupervisor/client.py", line 76, in _raise_on_status
    raise exc_type(result.message, result.job_id)
aiohasupervisor.exceptions.SupervisorBadRequestError: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.12.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.12.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/aarch64-hassio-supervisor/manifests/2024.12.3": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Faarch64-hassio-supervisor%3Apull&service=ghcr.io": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
    response = await hass.services.async_call(
    ...<7 lines>...
  File "/usr/src/homeassistant/homeassistant/core.py", line 2795, in async_call
    response_data = await coro
  File "/usr/src/homeassistant/homeassistant/core.py", line 2838, in _execute_service
    return await target(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1006, in entity_service_call
    single_response = await _handle_entity_call(
        hass, entity, func, data, call.context
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1078, in _handle_entity_call
    result = await task
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 157, in async_install
    await entity.async_install_with_progress(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 489, in async_install_with_progress
    await self.async_install(version, backup)
  File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 264, in async_install
    raise HomeAssistantError(
        f"Error updating Home Assistant Supervisor: {err}"
    ) from err
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.12.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.12.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/aarch64-hassio-supervisor/manifests/2024.12.3": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Faarch64-hassio-supervisor%3Apull&service=ghcr.io": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
