Hello, I am new here as I start to explore Home Assistant before ordering Home Assistant Green for home. My use case is to integrate Ring and Google Nest Thermostat with Apple HomeKit as those aren’t becoming HomeKit compatible anytime soon!
Before I order one of those kits, I wanted to sure if that “Green” device meet the proposed integration or have to invest more in “Yellow” support matter for example. I am a bit unclear on that front and hence any advice would be much appreciated
I had 7 Nests working in Homekit by utilizing a Starling Hub. About a year ago I took on an HA Green, and was able to get the Starling & Nests exposed there.
That is to suggest the Green should work out fine. I have to say that with the Thermostats working well, I’ve hesitated to see how those thermostats might get on with Matter instead of the Starling (I had tried the Google api integration w/o success at some point in time).
Thanks for that feedback…indeed reassuring! I believe it does work with Ring devices as well. Cheers
