I just got my HA green. I thought it would be plug-and-play but seems like something is wrong.
I disconnected my existing Pi and connected the green via ethernet.
I noticed two things:
1 On the HA Green console, there are 2 traces:
Core finish service code 1
Core service shutdown
2 On the common network between the mac and the HAGreen, the
Wireshark traces show that the HA Green responds with an RST message to the SYN message of the mac.
@BebeMischa: don’t bother, Stephen has given the solution.
OP is tying to access via httpS where as he doesn’t have TLS configured & he’s trying to use the CIDR as host address…
You don’t change the IP address of a device in the router. All this screenshot says is that there is something at 192.168.221.101, but not what device you are pinging.
Where did you get “101” from?
“This site can’t provide a secure connection”
Because you are using HTTPS:
If you are typing “http://192.168.221.52:8123” and the browser is “automagically” changing it to “https:”, then you need to go into your browser settings to turn off “Automatic HTTPS”.
This can be in your Privacy or Security section- every browser is different.
