Hi
I am using grid which is available througt home assistant.
Is there a way to control the width?
I can control how many colums there are but it is the same width
Hi
The cards are always evenly distributed along the row, making them the same width.
There are a couple of things you can do to vary this:
If you use a vertical stack card, with a different grid card for each row and more columns than you need in each grid card you can control the card size a bit by adding extra columns. Each row will still be uniform though.
You can also create “spacers” by using button cards with no entity specified.
Otherwise you need a frontend addon from HACS.
Edit: If you like, you can then make the card background transparent:
When I make a grid card the total width is fixed at 600px
