Home Assistant Groups
Hi fellow Home Assistanters!!
Quick question and easy question! I have a small room with 2 smart lamps and 2 smart plugs that control 2 other lights. How do I put them into a group so that I can press an icon and they turn off or on?
Ta
Set up a Group Helper, if they are all the same domain.
If they are mixed domains like switch and light you can either:
  1. Make proxy entities (also available in Helpers using the “Change device type of a switch” Helper). Then group those with the ones that were already lights in a Group Helper.
  2. Create a Legacy Style group in your configuration file.
