I’ve been having a pretty big problem with hassio for a short time that I can’t really get solved.
The interface freezes completely or is no longer accessible although the home assistant log is writing in the background all the time.
All automations do not work anymore.
The log files show me nothing.
I can still access the Raspberry via SSH.
Only a hard reboot helps in this case, so that I can get back to the interface.
The newest version is running everywhere and nothing is “outdated”.
Can someone help me how to proceed?
The whole thing is running on a Raspberry Pi 3.
Version core-2021.2.3
Operating System Home Assistant OS 5.11
Addons:
AdGuard Home Current version: 3.0.0 (changelog)
This morning I noticed the same issue. After the reboot it take much longer to load HA. I even restored my previous backup but with the same issue (i presume that I did backup my vm with that fault).
a quick update: I have pulled my older VM backups and restored the HA from version 0.118 to last 2021.2.3 without any issue. However, when I also updated the Operating System to version 5.11 the problem re-occurred:
I’m a first time user of Hass but I’ve run into the same issue. I’ve found out it is caused by doing a virgin boot from a freshly created image WITHOUT a network connection. The error will show on all subsequent boots even with a network connection. Solution: reflash image, make sure you have an internet connection and boot.
