I recently updated Home Assistant to 0.63.3 in my hassio v1.1 raspberry pi, and while home assistant reports that it’s running over ssh I’m unable to access the admin at :8123.
It spins for a really long time "waiting for 192.168.1.17…then after several minutes I’ll see the error “Home assistant had trouble connecting to the server”.
My console shows some errors
GET http://192.168.1.17:8123/static/mdi-6f045d22d553ce53c94e063400ed68af.html net::ERR_CONNECTION_RESET
(index):1 GET http://192.168.1.17:8123/frontend_latest/frontend-ebcb41952b21503c6a09065b084a638d.html net::ERR_CONNECTION_RESET
(index):1 GET http://192.168.1.17:8123/static/fonts/roboto/Roboto-Medium.ttf net::ERR_CONNECTION_RESET
(index):1 GET http://192.168.1.17:8123/static/fonts/roboto/Roboto-Regular.ttf net::ERR_CONNECTION_RESET
(index):1 GET http://192.168.1.17:8123/frontend_latest/core-aa5473dbea8ac5b75ae0e8239f8e0e38.js net::ERR_CONNECTION_REFUSED
(index):1 Uncaught (in promise) DOMException: Only secure origins are allowed (see: https://goo.gl/Y0ZkNV).
(anonymous) @ (index):1
I notice the last one, I’m using http not https, but surely that wouldn’t be causing everything to fail.
Pings to the IP come back in 10ms, so I don’t see why it would be taking so long…
It seems to be running fine from SSH:
core-ssh:~# hassio ha stop
"result": "ok",
"data": {}
core-ssh:~# hassio ha update
"result": "error",
"message": "Version 0.63.3 is already in use"
core-ssh:~# hassio ha start
"result": "ok",
"data": {}
Likewise, nothing out of the ordinary is showing up if I run hassio ha logs, it seems to be managing MQTT et al in the background.
I don’t see any notes about breaking changes in either 0.62 or 0.63…I’m not really sure how to go about debugging this. Can anyone provide any guidance? Thanks!
