Home assistant hangs after few hours
I checked the logs ( ha core logs ) and grepped for malformed.
Nothing there …
(tried top copy/paste the output, but the terminal addon doesnt facilitate copy/paste)
I added the logger config. Think there’s more info over there.
Check out https://github.com/home-assistant/operating-system/issues/1119
Lots of people with similar issues. When it freezes it looks like most of the time the logs don’t give a clue. Most in the 1119 issue can run fine on os below 5.5. This has been an issue for a lot of people after the kernel was change to make 5.5.
Yesterday I changed the recorder backend to MariaDB. Since then no hang :slight_smile:
A good video on how to achive this: https://youtu.be/0Nf70avId0w
And one day later, HA is dead again :unamused:
This is not good. Stability is crucial.
Have your tried the OS downgrade to 5.4. I have yet to have this crash. I just tried this morning an update to the firmware on my StarTech controller. I rebooted, went to 5.12 and 4 hours later it crashed. 5.4 is very stable for me.
RPI-4 clean install, no temp og memory problems - basically a decent installation but still experiencing hangs once a day for the last 2 months appx.
Any hints og news if someone is looking into this rather common issue?
I have the same issue now for several months, Systems freezes after 1 day - simple installation, new RaspberryPI with SD card, original power supply 2% CPU load, 58 degrees celcius, Disk 8%, Mem use 12%
recorder:
  purge_keep_days: 1
  commit_interval: 10
im still trying to resolve this issue unresponsive HA once everyday. I have set automation to reboot my HA every 6hours hoping this will solve the issue. I will update this ticket once it eliminates the issue.
Same here - tried almost everything. SD->SSD, cooling, disabled integration etc. etc.
I’m wondering if the devs are aware of this thread. I would post logs if I knew what they needed to diagnose the issue.
I’ve tried excluding sensors from the recorder, and I now have a sneaking suspicion, that it is an input_text value that is tripping up the recorder process.
My setup is now working again, after excluding it, purging the database, and restarting HA.
Will post again, once a day has past, to let you know it that worked.
Same here :man_facepalming:
Everything startet after switching from RPI3 to 4
Meanwhile i changed to the 3rd SSD adapter
I tested the SSD with blackmagic and crystaldiskmark nearby to the death
I use the original rpi power supply
I can’t see anything in the logs at all
Reboot / Fresh Install → 24 - 72h :: FREEZE !
actual i switched over to a A2 SD card instead of SSD
the next step would a try with 32Bit instead of 64Bit
lets see
really annoying :sleepy:
I had the same problem and a completely fresh install (no snapshot restore) seems to have fixed it. Details here: HassIO stops responding every so often - #75 by bradymholt
This sounds just like my case. Did you find a fix to this?
Thanks in advance!
Worked for me to exclude that custom input_text entity from the recorder!
Could you share an example on how to apply this workaround?
Sure!
I started with excluding all domain types from being recorded (see below), restarting HA, and checking the logs to see if stuff was being recorded again.
Then I progressively enabled domains again, by commenting out those lines (see below).
Finally, I figured out it had to do with one of my custom input_text fields. So leaving that excluded got everything stable and working again.
recorder:
  exclude:
    domains:
      - automation
      # - binary_sensor
      - camera
      # - climate
      - device_tracker
      # - group
      # - input_boolean
      - input_text
      # - light
      # - person
      # - sensor
      - sun
      # - switch
      - water_heater
      - weather
      - weblink
      - updater
      - zone
Thx, I had the same issue and it’s better now with your trick.
