The last few week i’m have trouble with the performance of my rasberry pi 3b+.
restarting home assistant takes over 5 min and i’m looking for alternative ways to host my home assistant.
for my job i’m using a lot of windows server hyper-v so i prefer running it in a vm but i’m using rfxtrx device for some switches and my doorbell and i’m thinking of buying a conbee 2.
i found a hacs intergration called home-assistant remote and this is working but sometings there is a delay when i change a status of my switch.
are there any alternative ways to combine 2 instances of home assistant or is the best way to solve my problem to buy a intel nuc?
I can recommend old workstations like a Dell Optiplex from eBay for under $100. Great BYFB. In many cases, much cheaper that buying a Pi4+SSD/SD+PSU+Case, and more versatile.
Dell Optiplex 9020 #FTMFW. I have 4 of them running in my server cabinet. A little tight on space internally, but the damn things are built like tanks.
If you go with a RPi4, there’s a prebuilt image you flash to a SD card (or SSD or USB flashdrive, etc) that you can use. Or, you can install Linux and download a Docker container (which is how I usually roll).
If you go with other hardware (again, Dell Optiplex 9020 #FTMFW!), just install any Linux distro on it (Ubuntu and Debian based distros work very well) and use the Docker method.
For my work we use only Windows servers no Linux based servers so i have zero experience with Linux and dockers
What i like about home assistant os is that i van update it trough the ui
LEARN LINUX! (No really… it’s actually super easy compared to even 5 years ago).
With that said, I’d go with a rPI4 2GB model and just use the Home Assistant system install. You flash it, pop it into the Pi (like you are doing today) and you’re off to the races.
No thats not what i meant.
I want to run a home assistant installation in a pi3b+ and my hyper-v vm.
And i Will use my pi for usb devices en my vm for all the automations
There is a hacs intergration home-assistant remote that can pull all your devices from a other installation.
In that way i can create a master and slave
