Home assistant health check but for integrations also
  home-assistant:
    image: homeassistant/home-assistant
    container_name: home-assistant
    hostname: home-assistant
    restart: unless-stopped
    cap_add:
      - NET_RAW
      - NET_ADMIN
    user: "0"
    network_mode: host
    environment:
      TZ: ${TZ}
    volumes:
      - /run/dbus:/run/dbus:ro
      - ./config/home-assistant:/config
    depends_on:
      mariadb:
        condition: service_healthy
    extra_hosts:
      - "mariadb:172.20.0.101"
      - "frigate:172.20.0.102"
      - "mosquitto:172.20.0.103"
Is there a health check I can add to home assistant, that will not only make sure that home assistant has started, but also all the integrations have been started also?
The reason is that other containers, like node-red, depend on home assistant being fully started before they start, otherwise they produce errors, and some of the flows don’t activate unless home assistant is fully started.
If you just want to know when HA has fully started & loaded all integrations, you could use the homeassistant_started event as a trigger to let your other containers know it’s safe to start.
Not sure how you’d pass that info to your other containers because I know next to nothing about Docker, but hopefully it’s enough to get you started.
Ideally it should be done in docker. For example mariadb uses this for health checks. Note the healthcheck: section
  mariadb:
    image: mariadb
    container_name: mariadb
    hostname: mariadb
    user: "0"
    environment:
      TZ: ${TZ}
      MARIADB_ROOT_PASSWORD: ${MARIADB_ROOT_PASSWORD}
    ports:
      - 3306:3306
    volumes:
      - ./config/mariadb/mysql:/var/lib/mysql
      - ./config/mariadb:/docker-entrypoint-initdb.d
    healthcheck:
      test: ["CMD", "healthcheck.sh", "--su-mysql", "--connect", "--innodb_initialized"]
      interval: 10s
      timeout: 5s
      retries: 10
      start_period: 30s
    networks:
      network:
        ipv4_address: 172.20.0.101
Happy to report that this is working
  home-assistant:
    cap_add:
      - NET_RAW
      - NET_ADMIN
    user: "0"
    network_mode: host
    environment:
      TZ: ${TZ}
      HA_TOKEN: ${HA_TOKEN}
    volumes:
    depends_on:
      mariadb:
    extra_hosts:
      - "piper:${IP_PIPER}"
      - "mariadb:${IP_MARIADB}"
      - "frigate:${IP_FRIGATE}"
      - "whisper:${IP_WHISPER}"
      - "mosquitto:${IP_MOSQUITTO}"
      - "wyoming-openai:${IP_WYOMING_OPENAI}"
    healthcheck:
      test: ["CMD-SHELL", "sh -c 'curl -s -H \"Authorization: Bearer $HA_TOKEN\" http://127.0.0.1:8123/api/config | grep -o \"\\\"state\\\":\\\"RUNNING\\\"\" > /dev/null'"]
      interval: 30s
      timeout: 10s
      retries: 5
      start_period: 120s
and now I can have node-red start after home-assistant has started and finished loading all integrations.
  node-red:
    image: nodered/node-red
    container_name: node-red
    hostname: node-red
    user: "0"
    environment:
      TZ: ${TZ}
    ports:
      - 1880:1880
    volumes:
      - ./config/node-red:/data
    entrypoint: >
      sh -c "
        echo 'checking if required modules exist';
        if [ ! -d /data/node_modules/node-red-contrib-home-assistant-websocket ]; then
          echo 'installing required modules';
          npm install --prefix /data --no-audit --no-update-notifier --no-fund node-red-contrib-home-assistant-websocket@latest;
        else
          echo 'required modules exist';
        fi;
        echo 'starting node-red';
        exec node-red --userDir /data"
    depends_on:
      home-assistant:
    networks:
      network:
    extra_hosts:
      - "home-assistant:host-gateway"
