I really need you help. I’ve a Home Assistant installed in a MELE PC which supports WoL.
I’ve enabled the Wake On Lan from the BIOS and also on Router but it is not working as expected.
I’ve tried to add “ethtool” to check the network adapter config in the machine but it is not working.
Is there a configuration to add or a parameter to enable to ensure WoL for HA Host.
