Home Assistant ICONS for Stream Deck
From the recent “Community Highlights: 8th edition” I learned about a new way to use Stream Deck to integrate to Home Assistant leveraging the following project from @cgiesche: GitHub / cgiesche / streamdeck-homeassistant which I have to comment works Great!! If you have a Stream Deck, try it out!!
Here is the Issue… There seems to be a lack of MDI type Device Icons for Stream Deck. I am starting to build out what I need but I wanted to reach out to the community to see if there are any additional resources. Please share any Icons or Tips for using Stream Deck in a home automation work flow.
Cheers!!
As well as MDI icons you can use Simpleicons with this custom integration:
I also love this intergration and its something I waited for quit some time to retire my Homey as there was a StreamDeck Plugin there already and HomeAssistant didn´t have one until now.
Unfortunately I also don´t like the way the keys on my StreamDeck look. For example:
I do have a whole set of Icons I downloade and also made some in Photoshop by myself. Unfortunately it seem like the HomeAssistand Streamdeck Plugin cant handle my custom icons.
As you can see in the Screenshot. I am able to use a nice Icon which shows the current power drawn from my PC setup with the Homey Integration. With the Home Assistant Integration I´m only able to show the number and nothing else.
Do you guys know if there is a way to use custom icons?
Regards!
Hey checkout the 300+ Smart-Home Icons
