Home assistant installed but too many errors
Hi all!
I have just started with home assistant but despite my efforts searching this community and on google I have not find a solution for my problem. First of all I still don’t understand what the problem exactly is so hopefully you can help me. I am quite new to python so I might not understand everything immediately.
Where have I installed homeassistant on?
I have installed it on an old android tablet running lineageos 14.1 installed through Termux in venv
This are my logbook:
2021-07-25 20:46:39 INFO (MainThread) [homeassistant.bootstrap] Config directory: /data/data/com.termux/files/home/.homeassistant
2021-07-25 20:46:39 INFO (SyncWorker_1) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2021-07-25 20:46:39 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2021-07-25 20:46:39 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds
2021-07-25 20:46:39 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2021-07-25 20:46:39 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded met from homeassistant.components.met
2021-07-25 20:46:39 INFO (SyncWorker_1) [homeassistant.loader] Loaded cast from homeassistant.components.cast
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2021-07-25 20:46:39 INFO (SyncWorker_1) [homeassistant.loader] Loaded sonos from homeassistant.components.sonos
2021-07-25 20:46:39 INFO (SyncWorker_1) [homeassistant.loader] Loaded tplink from homeassistant.components.tplink
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded group from homeassistant.components.group
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded scene from homeassistant.components.scene
2021-07-25 20:46:39 INFO (SyncWorker_1) [homeassistant.loader] Loaded script from homeassistant.components.script
2021-07-25 20:46:39 INFO (SyncWorker_1) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded synology_dsm from homeassistant.components.synology_dsm
2021-07-25 20:46:39 INFO (SyncWorker_1) [homeassistant.loader] Loaded blueprint from homeassistant.components.blueprint
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded http from homeassistant.components.http
2021-07-25 20:46:39 INFO (SyncWorker_1) [homeassistant.loader] Loaded network from homeassistant.components.network
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded trace from homeassistant.components.trace
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded counter from homeassistant.components.counter
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded dhcp from homeassistant.components.dhcp
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded api from homeassistant.components.api
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded config from homeassistant.components.config
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded device_automation from homeassistant.components.device_automation
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded analytics from homeassistant.components.analytics
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded person from homeassistant.components.person
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded image from homeassistant.components.image
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded search from homeassistant.components.search
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded history from homeassistant.components.history
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded input_boolean from homeassistant.components.input_boolean
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded input_datetime from homeassistant.components.input_datetime
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded input_number from homeassistant.components.input_number
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded input_select from homeassistant.components.input_select
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded input_text from homeassistant.components.input_text
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded map from homeassistant.components.map
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded media_source from homeassistant.components.media_source
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded tag from homeassistant.components.tag
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded my from homeassistant.components.my
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded timer from homeassistant.components.timer
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2021-07-25 20:46:39 INFO (SyncWorker_0) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2021-07-25 20:46:39 INFO (SyncWorker_2) [homeassistant.loader] Loaded zone from homeassistant.components.zone
2021-07-25 20:46:39 INFO (MainThread) [homeassistant.bootstrap] Domains to be set up: {‘lovelace’, ‘zone’, ‘sun’, ‘automation’, ‘tplink’, ‘history’, ‘person’, ‘frontend’, ‘updater’, ‘input_datetime’, ‘cast’, ‘input_text’, ‘sonos’, ‘network’, ‘default_config’, ‘input_boolean’, ‘device_automation’, ‘logbook’, ‘config’, ‘map’, ‘scene’, ‘http’, ‘system_health’, ‘met’, ‘recorder’, ‘system_log’, ‘webhook’, ‘cloud’, ‘media_source’, ‘websocket_api’, ‘analytics’, ‘input_number’, ‘group’, ‘synology_dsm’, ‘auth’, ‘script’, ‘tts’, ‘api’, ‘dhcp’, ‘trace’, ‘image’, ‘timer’, ‘search’, ‘counter’, ‘my’, ‘onboarding’, ‘zeroconf’, ‘blueprint’, ‘tag’, ‘mobile_app’, ‘input_select’, ‘ssdp’}
2021-07-25 20:46:39 INFO (MainThread) [homeassistant.bootstrap] Setting up logging: {‘recorder’, ‘system_log’}
2021-07-25 20:46:41 INFO (MainThread) [homeassistant.setup] Setting up recorder
2021-07-25 20:46:41 INFO (MainThread) [homeassistant.setup] Setting up http
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.1 seconds
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setting up system_log
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.7 seconds
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {‘lovelace’, ‘http’, ‘api’, ‘webhook’, ‘cloud’, ‘image’, ‘websocket_api’, ‘person’, ‘device_automation’, ‘analytics’, ‘config’, ‘search’, ‘onboarding’, ‘frontend’, ‘system_log’, ‘auth’}
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setting up api
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setting up webhook
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setting up config
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setting up auth
2021-07-25 20:46:42 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds
2021-07-25 20:46:43 INFO (MainThread) [homeassistant.setup] Setting up image
2021-07-25 20:46:44 INFO (MainThread) [homeassistant.setup] Setting up analytics
2021-07-25 20:46:44 INFO (MainThread) [homeassistant.setup] Setup of domain config took 1.8 seconds
2021-07-25 20:46:44 INFO (MainThread) [homeassistant.setup] Setting up search
2021-07-25 20:46:44 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds
2021-07-25 20:46:44 INFO (SyncWorker_2) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
2021-07-25 20:46:44 INFO (SyncWorker_1) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa
2021-07-25 20:46:44 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 1.9 seconds
2021-07-25 20:46:44 INFO (SyncWorker_0) [homeassistant.loader] Loaded camera from homeassistant.components.camera
2021-07-25 20:46:44 INFO (MainThread) [homeassistant.setup] Setup of domain image took 1.0 seconds
2021-07-25 20:46:44 INFO (MainThread) [homeassistant.setup] Setup of domain analytics took 0.2 seconds
2021-07-25 20:46:44 INFO (SyncWorker_3) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2021-07-25 20:46:44 INFO (MainThread) [homeassistant.setup] Setting up person
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up cloud
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.2 seconds
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setup of domain person took 1.8 seconds
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.0 seconds
2021-07-25 20:46:46 INFO (SyncWorker_0) [homeassistant.loader] Loaded hassio from homeassistant.components.hassio
2021-07-25 20:46:46 INFO (SyncWorker_3) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2021-07-25 20:46:46 INFO (SyncWorker_1) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up frontend
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {‘zone’, ‘sun’, ‘tplink’, ‘automation’, ‘history’, ‘updater’, ‘input_datetime’, ‘cast’, ‘input_text’, ‘sonos’, ‘network’, ‘default_config’, ‘input_boolean’, ‘logbook’, ‘map’, ‘scene’, ‘system_health’, ‘met’, ‘media_source’, ‘input_number’, ‘group’, ‘synology_dsm’, ‘script’, ‘tts’, ‘my’, ‘dhcp’, ‘trace’, ‘timer’, ‘counter’, ‘tag’, ‘zeroconf’, ‘blueprint’, ‘mobile_app’, ‘input_select’, ‘ssdp’}
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up zone
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up sun
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.1 seconds
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up history
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up updater
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up input_datetime
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up input_text
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up logbook
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up map
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up scene
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2021-07-25 20:46:46 INFO (MainThread) [homeassistant.setup] Setting up system_health
2021-07-25 20:46:47 INFO (MainThread) [homeassistant.setup] Setting up met
2021-07-25 20:46:47 INFO (MainThread) [homeassistant.setup] Setup of domain met took 0.0 seconds
2021-07-25 20:46:47 INFO (MainThread) [homeassistant.setup] Setting up media_source
If this is not the right place or topic I hope you will refer me to the right place.
I hope this is enough information.
You’re clearly using a non-standard, unsupported install method, but I don’t see a single error there. What’s wrong?
Oops I didn’t know this was unsupported. It states invalid configuration problem with default_config
Error1:
Logger: homeassistant.setup
Source: setup.py:173
First occurred: 20:46:53 (1 occurrences)
Last logged: 20:46:53
Setup failed for default_config: Could not set up all dependencies.
Error 2:
Source: setup.py:153
Unable to set up dependencies of default_config. Setup failed for dependencies: dhcp
Error 3:
Source: components/dhcp/init.py:17
First occurred: 20:46:49 (1 occurrences)
Last logged: 20:46:49
Setup failed for dhcp: unknown error
File “/data/data/com.termux/files/home/hass/lib/python3.9/site-packages/homeassistant/setup.py”, line 201, in _async_setup_component
component = integration.get_component()
File “/data/data/com.termux/files/home/hass/lib/python3.9/site-packages/homeassistant/loader.py”, line 490, in get_component
cache[self.domain] = importlib.import_module(self.pkg_path)
File “/data/data/com.termux/files/usr/lib/python3.9/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1030, in _gcd_import
File “”, line 1007, in _find_and_load
File “”, line 986, in _find_and_load_unlocked
File “”, line 680, in _load_unlocked
File “”, line 850, in exec_module
File “”, line 228, in _call_with_frames_removed
File “/data/data/com.termux/files/home/hass/lib/python3.9/site-packages/homeassistant/components/dhcp/init.py”, line 17, in
from scapy.arch.common import compile_filter
File “/data/data/com.termux/files/home/hass/lib/python3.9/site-packages/scapy/arch/init.py”, line 135, in
_set_conf_sockets() # Apply config
File “/data/data/com.termux/files/home/hass/lib/python3.9/site-packages/scapy/config.py”, line 618, in _set_conf_sockets
conf.ifaces.reload()
File “/data/data/com.termux/files/home/hass/lib/python3.9/site-packages/scapy/interfaces.py”, line 238, in reload
self._reload_provs()
File “/data/data/com.termux/files/home/hass/lib/python3.9/site-packages/scapy/interfaces.py”, line 234, in _reload_provs
self._load(prov.reload(), prov)
File “/data/data/com.termux/files/home/hass/lib/python3.9/site-packages/scapy/interfaces.py”, line 53, in reload
return self.load()
File “/data/data/com.termux/files/home/hass/lib/python3.9/site-packages/scapy/arch/linux.py”, line 420, in load
get_if_raw_hwaddr(i, siocgifhwaddr=SIOCGIFHWADDR)[1]
File “/data/data/com.termux/files/home/hass/lib/python3.9/site-packages/scapy/arch/common.py”, line 87, in get_if_raw_hwaddr
get_if(iff, siocgifhwaddr)
File “/data/data/com.termux/files/home/hass/lib/python3.9/site-packages/scapy/arch/common.py”, line 65, in get_if
return ioctl(sck, cmd, struct.pack(“16s16x”, iff.encode(“utf8”)))
PermissionError: [Errno 13] Permission denied
Is this helpfull?
Use one of the supported installation platforms & methods as listed in the documentation here.
What was the reference you used that implied this was a viable way of installing Home Assistant?
On this forum there is an installation guideline how to install on android. Therefore I thought it must be possible.
My synology doesn’t support docker so the cheapest option is a raspberry pi I think.
Is the pi 4 with 4gb ram and 32 gb sd card enough in terms of specs? Or should I go for 8gb ram
The community guides section says:
Please note, guides provided in this section may be outdated/broken and are not supported by Home Assistant. Use these at your own risk.
Pi with 4 GB is a perfectly fine starting point
Thank you all. I will buy a raspberry pi and try again.
Instructions are clear.
If you want to keep your android instance, you need to change source code because termux has a different file address for ‘resolve.conf’. on the other hand, this is not a show stopper, i have survived with android more than 6 months and recently migrated to pi for the sake of having a screen.
