I have installed HA from an image downloaded from the website. Now I think I could install a native rapberry OS and install HA then so I still have possibility to install other linux software (for example cups) and even integrate them later with HA (if possible). My question is, if I can make any HA backup now, install new Raspberry Pi OS, install HA on Raspberry Pi OS and recover the backup?
Yes you can do that but how you do it depends on how you installed the new HA.
If you use a “HA Supervised” install then just take a snapshot of the existing system and restore it to the new one.
If you install “HA Container” then you need to copy the entire contents of the config folder (including all hidden files/folders) and the copy those to the new config folder once HA is installed on the new machine.
am hoping someone can help me… I was running hassio in virtual box and recently switched to vmware workstation. I built a new image from scratch and then loaded my config files. Everything has seemed to go ok. With one difference. When I reboot my system and have to restart the vm, I watch hassio io go thru it typical boot sequence. When it is done. I get the following in the vm window:
Welcome to Home Assistant
homeassistant login:
I can login using root, and it logs me in to the ha cli…Initially lovelace will not load. not sure what is going on, can someone explain?
