Home Assistant instance with identical name present in the local network
I have two Instances of HA running, the first my main system
Hostname
homeassistant
The second
Hostname
Development-System
How can I clear this error in my log
Logger: homeassistant.components.zeroconf
Source: components/zeroconf/__init__.py:211
Integration: Zero-configuration networking (zeroconf) (documentation, issues)
First occurred: 7:35:02 (1 occurrences)
Last logged: 7:35:02
Configuration > General > Name of your homeassistant instance
Here?
Are they both called home?
Yeah, but as the text says you’ll have to change yours in your configuration.yaml as you haven’t migrated.
I think you need to change the host name not the name of the instance.
This can be done from the supervisor panel under the system tab. If your not running Hassos follow the instructions for your OS.
His hostnames are already different, says so in the OP.
