Home Assistant Interface Unstable
I installed Home Assistant yesterday and configured couple devices and now I have to keep refreshing for the ui pages to load and also sometimes when I reboot Home Assistant VM. I get following message
home assistant cli is not running emergency console
Need help troubleshooting it.
OK: what are you running on, and how did you install it?
I am running it as VM on Proxmox I downloaded VirtualBox VDI from here
It seems all connections reset maybe
Can this be causing the issue?
2021-04-13 05:56:33 WARNING (zeroconf-Engine-243) [zeroconf] Choked at offset 33020 while unpacking b'\x00\x00\x00\x00\x00\x04\x00\x00\x00\x07\x00\x00\x07home251\x05local\x00\x00\xff\x00\x01*home251 [6b3a524712af4f9ea0d855614a1ecba7]\x0c_workstation\x04_tcp\xc0\x14\x00\xff\x00\x01*home245 [6b3a524712af4f9ea0d855614a1ecba7]\xc0J\x00\xff\x00\x01*home233 [6b3a524712af4f9ea0d855614a1ecba7]\xc0J\x00\xff\x00\x01*home231 [6b3a524712af4f9ea0d855614a1ecba7]\xc0J\x00\xff\x00\x01\xc0\x93\x00\x10\x80\x01\x00\x00\x00x\x00\x01\x00\xc0\x93\x00!\x80\x01\x00\x00\x00x\x00\x15\x00\x00\x00\x00\x00\x00\x07home233\x05local\x00\xc0\x0c\x00\x01\x80\x01\x00\x00\x00x\x00\x04\xc0\xa8P<\xc0\x1f\x00\x10\x80\x01\x00\x00\x00x\x00\x01\x00\xc0\x1f\x00!\x80\x01\x00\x00\x00x\x00\x15\x00\x00\x00\x00\x00\x00\x07home251\x05local\x00\xc0b\x00\x10\x80\x01\x00\x00\x00x\x00\x01\x00\xc0b\x00!\x80\x01\x00\x00\x00x\x00\x15\x00\x00\x00\x00\x00\x00\x07home245\x05local\x00'
  File "/usr/local/lib/python3.8/site-packages/zeroconf/__init__.py", line 745, in __init__
    self.read_others()
  File "/usr/local/lib/python3.8/site-packages/zeroconf/__init__.py", line 816, in read_others
    domain = self.read_name()
  File "/usr/local/lib/python3.8/site-packages/zeroconf/__init__.py", line 877, in read_name
    length = self.data[off]
IndexError: index out of range
I don’t know, sorry: I have no experience with VM setups. Hopefully an expert in that area will be along to answer — I was just getting the information that anyone would need to help you further.
I believe you are choosing the wrong image to install on Proxmox.
Anyway there are some guidelines to install it from Install Proxmox and virtualize Home Assistant | JuanMTech
OR you can try to install using Debian + HA + Supervised version which is 100% stable.
You could also try the script from whiskerz007
it basically does all the work for you in proxmox
@Troon @Luitertje I had added a second network interface. After removing the second network interface it fixed.
