Home Assistant iOS app not able to connect when using specific access point
Hi there. I have a strange situation and I cannot figure out what’s going on. The Home Assistant iOS app is not able to connect to my local Home Assistant setup (docker, all up to date, working fine) when I move to another access point in the house (I use two Unifi In-Wall AP’s without any special rules on the internal network). It’s only the HA app that is not working on my iPhone. I don’t see anything being blocked on the AP logs, nor anything on the HA logs so I don’t have a lead to go on.
Any advise on how to approach this issue is appreciated!
Use a computer and connect to each of them and run the cmd command ipconfig /all and paste them here.
I doubt there will be any sensitive information but just as a precaution, make sure the IPs in the list is only 192… if they are anything else then mask it for now.
Same thing, if you don’t want to disclose the SSID of your access points then mask that too. But it’s nothing that is sensitive in my opinion since it is broadcasted anyways…
