Hey all,
multiple reboots and home assistant never starts up, things like HACS etc dont seem load and i cant work out how to get things running again?
Getting some weird errors ive not seen below.
HassOS 4.10
Supervisor: Version 228
RPI4, 4GB
Home Assistant 0.112.1
System Health
arch | armv7l |
chassis | embedded |
dev | false |
docker | true |
docker_version | 19.03.8 |
hassio | true |
host_os | HassOS 4.10 |
installation_type | Home Assistant OS |
os_name | Linux |
os_version | 4.19.126-v7l |
python_version | 3.7.7 |
supervisor | 228 |
timezone | Europe/London |
version | 0.112.1 |
virtualenv | false |
20-07-03 08:35:45 INFO (SyncWorker_9) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-cli with version 25
20-07-03 08:35:45 INFO (MainThread) [supervisor.plugins.cli] Start cli plugin
20-07-03 08:35:47 INFO (SyncWorker_0) [supervisor.docker.cli] Start CLI homeassistant/armv7-hassio-cli with version 25 - 172.30.32.5
20-07-03 08:35:47 INFO (SyncWorker_12) [supervisor.docker.interface] Attach to homeassistant/armv7-hassio-multicast with version 2
20-07-03 08:35:47 INFO (MainThread) [supervisor.plugins.multicast] Start Multicast plugin
20-07-03 08:35:48 INFO (SyncWorker_5) [supervisor.docker.multicast] Start Multicast homeassistant/armv7-hassio-multicast with version 2 - Host
20-07-03 08:35:48 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-07-03 08:35:49 INFO (SyncWorker_15) [supervisor.docker.interface] Attach to homeassistant/raspberrypi4-homeassistant with version 0.112.0
20-07-03 08:35:49 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /
20-07-03 08:35:49 INFO (MainThread) [supervisor.hassos] Detect HassOS 4.10 / BootSlot B
20-07-03 08:35:50 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/a0d7b954 repository
20-07-03 08:35:50 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/8c1e12d6 repository
20-07-03 08:35:50 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/core repository
20-07-03 08:35:50 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/ae6e943c repository
20-07-03 08:35:50 INFO (MainThread) [supervisor.store.git] Load add-on /data/addons/git/7ad98f9c repository
20-07-03 08:35:51 INFO (MainThread) [supervisor.store] Load add-ons from store: 71 all - 71 new - 0 remove
20-07-03 08:35:51 INFO (MainThread) [supervisor.addons] Found 7 installed add-ons
20-07-03 08:35:51 INFO (SyncWorker_2) [supervisor.docker.interface] Attach to homeassistant/armv7-addon-check_config with version 3.3.0
20-07-03 08:35:51 INFO (SyncWorker_14) [supervisor.docker.interface] Attach to homeassistant/armv7-addon-samba with version 9.2.0
20-07-03 08:35:51 INFO (SyncWorker_1) [supervisor.docker.interface] Attach to homeassistant/armv7-addon-configurator with version 5.0.0
20-07-03 08:35:51 INFO (SyncWorker_13) [supervisor.docker.interface] Attach to hassioaddons/ide-armv7 with version 2.2.0
20-07-03 08:35:51 INFO (SyncWorker_12) [supervisor.docker.interface] Attach to homeassistant/armhf-addon-deconz with version 5.3.6
20-07-03 08:35:51 INFO (SyncWorker_8) [supervisor.docker.interface] Attach to hassioaddons/glances-armv7 with version 0.8.0
20-07-03 08:35:51 INFO (SyncWorker_5) [supervisor.docker.interface] Attach to homeassistant/armv7-addon-ssh with version 8.6.0
20-07-03 08:35:51 INFO (MainThread) [supervisor.snapshots] Found 20 snapshot files
20-07-03 08:35:51 INFO (MainThread) [supervisor.discovery] Load 1 messages
20-07-03 08:35:51 INFO (MainThread) [supervisor.ingress] Load 3 ingress session
20-07-03 08:35:51 INFO (MainThread) [supervisor.misc.secrets] Load Home Assistant secrets: 116
20-07-03 08:35:51 INFO (MainThread) [__main__] Run Supervisor
20-07-03 08:35:51 INFO (MainThread) [supervisor.api] Start API on 172.30.32.2
20-07-03 08:35:51 INFO (MainThread) [supervisor.utils.gdbus] Call de.pengutronix.rauc.Installer.Mark on /
20-07-03 08:35:51 INFO (MainThread) [supervisor.hassos] Rauc: B - marked slot kernel.1 as good
20-07-03 08:35:51 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' start 0 add-ons
20-07-03 08:35:51 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' start 0 add-ons
20-07-03 08:35:51 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' start 5 add-ons
20-07-03 08:35:53 INFO (SyncWorker_5) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-samba with version 9.2.0
20-07-03 08:35:55 INFO (SyncWorker_3) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-ssh with version 8.6.0
20-07-03 08:36:01 INFO (SyncWorker_7) [supervisor.docker.addon] Start Docker add-on hassioaddons/ide-armv7 with version 2.2.0
20-07-03 08:36:17 INFO (SyncWorker_1) [supervisor.docker.addon] Start Docker add-on homeassistant/armhf-addon-deconz with version 5.3.6
20-07-03 08:36:17 WARNING (SyncWorker_14) [supervisor.docker.addon] Glances run with disabled protected mode!
20-07-03 08:36:18 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_ide
20-07-03 08:36:19 INFO (SyncWorker_14) [supervisor.docker.addon] Start Docker add-on hassioaddons/glances-armv7 with version 0.8.0
20-07-03 08:36:22 INFO (MainThread) [supervisor.api.security] /host/info access from a0d7b954_glances
20-07-03 08:36:24 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_glances
20-07-03 08:36:24 INFO (SyncWorker_11) [supervisor.docker.interface] Start homeassistant/raspberrypi4-homeassistant
20-07-03 08:36:27 INFO (MainThread) [supervisor.api.security] /dns/info access from a0d7b954_ide
20-07-03 08:36:50 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-07-03 08:36:55 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-07-03 08:37:15 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-07-03 08:37:51 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/config:
20-07-03 08:44:58 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/config:
20-07-03 08:45:34 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/config:
20-07-03 08:47:16 WARNING (MainThread) [supervisor.homeassistant] Don't wait anymore of Home Assistant startup!
20-07-03 08:47:16 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' start 1 add-ons
20-07-03 08:47:18 INFO (SyncWorker_8) [supervisor.docker.addon] Start Docker add-on homeassistant/armv7-addon-configurator with version 5.0.0
20-07-03 08:47:23 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
20-07-03 08:47:23 INFO (MainThread) [supervisor.misc.hwmon] Started Supervisor hardware monitor
20-07-03 08:47:23 INFO (MainThread) [supervisor.core] Supervisor is up and running
20-07-03 08:47:23 INFO (MainThread) [supervisor.host.info] Update local host information
20-07-03 08:47:23 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-07-03 08:47:23 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-07-03 08:47:24 INFO (MainThread) [supervisor.host.services] Update service information
20-07-03 08:47:24 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-07-03 08:47:24 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-07-03 08:47:24 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-07-03 08:47:24 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-07-03 10:47:23 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-07-03 10:54:03 INFO (MainThread) [supervisor.host.info] Update local host information
20-07-03 10:54:03 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
20-07-03 10:54:04 INFO (MainThread) [supervisor.host.services] Update service information
20-07-03 10:54:04 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
20-07-03 10:54:04 INFO (MainThread) [supervisor.host.network] Update local network DNS information
20-07-03 10:54:04 INFO (MainThread) [supervisor.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
20-07-03 10:54:04 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
20-07-03 11:47:23 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons-development repository
20-07-03 11:47:23 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/kevinvincent/hassio-addons repository
20-07-03 11:47:23 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/hassio-addons repository
20-07-03 11:47:23 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/danielwelch/hassio-zigbee2mqtt repository
20-07-03 11:47:23 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
20-07-03 11:47:25 INFO (MainThread) [supervisor.store] Load add-ons from store: 71 all - 0 new - 0 remove
20-07-03 11:52:15 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.112.1
20-07-03 11:52:15 INFO (SyncWorker_11) [supervisor.docker.interface] Update image homeassistant/raspberrypi4-homeassistant:0.112.0 to homeassistant/raspberrypi4-homeassistant:0.112.1
20-07-03 11:52:15 INFO (SyncWorker_11) [supervisor.docker.interface] Pull image homeassistant/raspberrypi4-homeassistant tag 0.112.1.
20-07-03 12:02:45 INFO (SyncWorker_11) [supervisor.docker.interface] Stop homeassistant application
20-07-03 12:03:21 INFO (SyncWorker_11) [supervisor.docker.interface] Clean homeassistant application
20-07-03 12:03:22 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-07-03 12:03:24 INFO (SyncWorker_10) [supervisor.docker.homeassistant] Start homeassistant homeassistant/raspberrypi4-homeassistant with version 0.112.1
20-07-03 12:03:44 INFO (MainThread) [supervisor.homeassistant] Updated Home Assistant API token
20-07-03 12:03:44 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-07-03 12:04:13 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-07-03 12:11:47 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/config:
20-07-03 12:14:14 WARNING (MainThread) [supervisor.homeassistant] Don't wait anymore of Home Assistant startup!
20-07-03 12:14:14 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished coro=<process_lock.<locals>.wrap_api() done, defined at /usr/src/supervisor/supervisor/utils/__init__.py:22> exception=HomeAssistantUpdateError()>
File "/usr/src/supervisor/supervisor/utils/__init__.py", line 31, in wrap_api
return await method(api, *args, **kwargs)
File "/usr/src/supervisor/supervisor/homeassistant.py", line 362, in update
raise HomeAssistantUpdateError()
supervisor.exceptions.HomeAssistantUpdateError
## Log Details (ERROR)
Logger: homeassistant.core
Source: core.py:157
First occurred: 14:44:35 (5 occurrences)
Last logged: 15:04:13
Error doing job: Unclosed client session
Last part of the full log
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 136, in async_refresh
self.data = await self._async_update_data()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 124, in _async_update_data
return await self.update_method()
File "/usr/src/homeassistant/homeassistant/components/withings/common.py", line 747, in async_get_all_data
None,
File "/usr/src/homeassistant/homeassistant/components/withings/common.py", line 745, in <genexpr>
if flow.context == context
AttributeError: 'dict' object has no attribute 'context'
2020-07-03 15:04:30 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry My home for smartthings
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 220, in async_setup
hass, self
File "/usr/src/homeassistant/homeassistant/components/smartthings/__init__.py", line 123, in async_setup_entry
entry.data[CONF_REFRESH_TOKEN],
File "/usr/local/lib/python3.7/site-packages/pysmartthings/smartthings.py", line 210, in generate_tokens
client_id, client_secret, refresh_token
File "/usr/local/lib/python3.7/site-packages/pysmartthings/api.py", line 424, in generate_tokens
raise APIInvalidGrant(data.get("error_description"))
pysmartthings.errors.APIInvalidGrant: Invalid refresh token: ab1c154d-0823-42f6-a711-9ef643c02207
2020-07-03 15:04:33 WARNING (MainThread) [homeassistant.components.konnected.panel] Exception trying to connect to panel:
2020-07-03 17:08:41 ERROR (MainThread) [snitun.multiplexer.core] Ping fails, no response from peer
2020-07-03 19:14:27 ERROR (MainThread) [snitun.multiplexer.core] Ping fails, no response from peer
