On updating to 0.112.4 my instance is permanently displaying Home Assistant is starting, please wait...
, literally for days now. Nothing unusual in the logs. Any suggestions how to resolve this?
Are there messages in your logs about the database conversion?
Hi @petro
the following is repeated over and over in the logs:
JSON file not found: /usr/src/homeassistant/homeassistant/components/recorder/translations/en.json
JSON file not found: /usr/src/homeassistant/homeassistant/components/camera/translations/en-GB.json
Note I am using docker
those are translation files. Odd. Might want to write up an issue. I’d try to roll back. Seems like you’re missing key files.
I did manually delete some hidden folders in config dir (attempting to remove some annoying warnings about HACS which I already deleted), perhaps that had unintended consequences. I think I will delete existing container and start afresh. Cheers
UPDATE: performed the removal, clean docker container, still have the error. Added to this issue: https://github.com/home-assistant/core/issues/37931
UPDATE2: I stripped my config back to the absolute bare bones, restarted and hey presto HA is back online. I now will go through the process of adding everything back in until I find the cause of the issue
UPDATE3: this occurs when I reintroduce an onvif
camera…! In the logs:
There does appear to be multiple issues with this onvif integration, so I am just going to remove it.
