Jman2022
(Jman)
October 16, 2022, 8:16pm
1
I just installed Home assistant and it says it’s unhealthy.
I can’t update or install addons it only shows errors
Your installation is unhealthy
Running an unhealthy installation will cause issues. Below is a list of issues found with your installation, click on the links to learn how you can resolve the issues.
What do I do, How do I fix it?
pedolsky
(Pedolsky)
October 16, 2022, 8:18pm
2
Didn’t the solution link help?
EdwardTFN
(Edward Firmo)
October 16, 2022, 8:24pm
3
After trying the links, I would suggest sharing more info about your system so you make easier for people to help you:
Which Home Assistant version are you currently running? Are you installing in a Raspberry Pi 4? RPi3? In a virtual machine? Etc.
Also take a look at Settings > System > Repairs and Settings > System > Logs… Share the relevant info with the community… Never share private info.
Jman2022
(Jman)
October 16, 2022, 8:30pm
5
Here’s a log called “Log Details (ERROR)”
Jman2022
(Jman)
October 16, 2022, 8:31pm
6
When I try to add an addon it shows an error
“‘AddonManager.install’ blocked from execution, system is not healthy”
When I try to update it says
Jman2022
(Jman)
October 16, 2022, 8:32pm
7
No I tried running the command “ha supervisor update” It gave me the same error
Update I have ran out of replies sense I just made this account today.
khvej8
(Khvej8)
8
Think it is either doing a update, not finished, or doing a backup.
EdwardTFN
(Edward Firmo)
October 16, 2022, 8:36pm
9
Is your Home Assistant connected to a network with Internet access? Is there any firewall or other blocker preventing Home Assistant to access the Internet?
Have you tried to reboot the host system? You will find it under Settings > System > Hardware:
B29
October 16, 2022, 8:38pm
11
Rpi with Home Assistant on sd card? Maybe is the sd card broken. Try a fresh install on a other sd card.
petro
(Petro)
October 16, 2022, 9:04pm
15
Why are you creating new accounts. Use the one you have. I set the level to member so you can post. Stop creating new accounts.
Jman2022
(Jman)
October 16, 2022, 9:12pm
17
I tried but still got the same error.
B29
October 17, 2022, 11:46am
18
Then I have no idea anymore.
pidiot
(Brian)
October 17, 2022, 2:53pm
19
my wife says the same thing to me (“Home assistant is unhealthy”) given how much time I spend configuring it
