Home Assistant Just Update Now experiencing issues
Hello All
This morning (Nov. 2, 2023) a number of installations occurred and home assistant also tried to update to the latest version 2023.11.0. It seemed to experience many issues with the installation and ultimately did not complete. I have tried to reinstall the latest version and I am now getting the error shown on the attached screenshot. I have rebooted and powered down several times with no luck.
Any advice? Should I reload that previously known working backup?
is your disk full? Seems to be having trouble doing backups.
Only at 1.2% of disk use. Lots of memory.
I had a similar experience where after a reboot the update hadn’t happened. I got a similat error message, not exactly sure of the contents though. HA had created a rollback log in the config directory that did not contain anything useful. When I tried the update again it went through.
One problem afterwards: some device id’s had changed, disabeling the scripts and automations involved. When I fixed those all was well.
same pb here
cannot upgrade either withUI or command line.
