Home Assistant keeps disconnecting and restarting
Hi everyone.
I set up my home assistant server a while back as a VM. Its been working great.
A few days ago I wanted to test out Frigate. I installed it on a with docker in a different machine with a Quadro P4000 for HW acceleration. I also install CompreFace on the same machine. The only thing that I installed on the Home Assistant VM was Double Take. Ever since, I’ve been running into issues with Home Assistant just loosing connection and reboot itself.
I am still in the process of narrowing it down, but I do believe that Double Take is the issue.
The thing that doesnt make sense to me, is that I get an error message on the console that reads:
“Out of Memory: Killed process 11644 (Python3) total-vm:26904840kB, anon-rss: 256kB, shmem-rss:0kB, UID:0, pgtables: 37736kB, oom_score_adj:-300”
The VM initially had 4GB of RAM allocated to to. I have tried allocating more RAM (12GB), but I still run into the same issue.
I also increase the storage from 32GB to 64GB
Can someone please help me in the right direction to get this solved?
Many thanks in advance
Hi Ettiene,
https://community.home-assistant.io/t/psa-alexa-media-player-v4-13-3-breaks-all-versions-of-home-assistant/778171 is likely why.
Thank you for your reply. What version would you recommend to downgrade to?
It’s not clear.
There is also this thread on the HA Discord of you want to keep track,
Awesome!! Thank you so much!!
This seems be to related to v4.13.3, i had v4.13.2 installed.
I did just downgrade to v4.12.11. Lets see what happens
Good luck…
Quick update.
I downgraded to V4.12.11 and it seems to be stable now.
Thank you
