The logs after every system startup - if that helps anything
2025-10-21 12:21:56.092 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration bureau_of_meteorology which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-10-21 12:21:56.093 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-10-21 12:21:56.094 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration powercalc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-10-21 12:21:56.095 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration currentcost which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-10-21 12:21:56.095 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-10-21 12:21:56.096 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration llmvision which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-10-21 12:21:56.096 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-10-21 12:21:56.097 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration frigate which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-10-21 12:21:56.098 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration tesla_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-10-21 12:21:56.098 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-10-21 12:21:56.099 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-10-21 12:21:57.151 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-10-21 12:21:57.170 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=544 from 2025-10-21 02:18:59.875585)
2025-10-21 12:21:57.430 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=(
Missing Entities: {{ states.sensor.watchman_missing_entities.state }}
{%- for item in state_attr(“sensor.watchman_missing_entities”, “entities”) %}
{%- endfor %}) renders=2>
File “/usr/src/homeassistant/homeassistant/helpers/template/
init.py”, line 494, in async_render
render_result = render_with_context(self.template, compiled, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/template/context.py”, line 45, in render_with_context
return template.render(**kwargs)
File “/usr/local/lib/python3.13/site-packages/jinja2/environment.py”, line 1295, in render
self.environment.handle_exception()
File “/usr/local/lib/python3.13/site-packages/jinja2/environment.py”, line 942, in handle_exception
raise rewrite_traceback_stack(source=source)
File “”, line 1, in top-level template code
jinja2.exceptions.UndefinedError: ‘None’ has no attribute ‘state’
File “/usr/src/homeassistant/homeassistant/helpers/template/init.py”, line 611, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
variables, strict=strict, log_fn=log_fn, **kwargs
File “/usr/src/homeassistant/homeassistant/helpers/template/init.py”, line 496, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: UndefinedError: ‘None’ has no attribute ‘state’
2025-10-21 12:21:57.964 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=(
{%- endfor %}) renders=6>
2025-10-21 12:22:01.110 WARNING (MainThread) [custom_components.sonoff] Can’t login in auto mode: AuthError(‘password error!’)
2025-10-21 12:22:03.515 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to open with args (‘/root/.netrc’,) inside the event loop by integration ‘google_generative_ai_conversation’ at homeassistant/components/google_generative_ai_conversation/init.py, line 165: await client.aio.models.get( (offender: /usr/local/lib/python3.13/netrc.py, line 87: with open(file, encoding=“utf-8”) as fp:), please create a bug report at GitHub · Where software is built
For developers, please see Blocking operations with asyncio | Home Assistant Developer Docs
File “”, line 198, in _run_module_as_main
File “”, line 88, in _run_code
File “/usr/src/homeassistant/homeassistant/main.py”, line 229, in
sys.exit(main())
File “/usr/src/homeassistant/homeassistant/main.py”, line 215, in main
exit_code = runner.run(runtime_conf)
File “/usr/src/homeassistant/homeassistant/runner.py”, line 271, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File “/usr/local/lib/python3.13/asyncio/base_events.py”, line 712, in run_until_complete
self.run_forever()
File “/usr/local/lib/python3.13/asyncio/base_events.py”, line 683, in run_forever
self._run_once()
File “/usr/local/lib/python3.13/asyncio/base_events.py”, line 2050, in _run_once
handle._run()
File “/usr/local/lib/python3.13/asyncio/events.py”, line 89, in _run
self._context.run(self._callback, *self._args)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 906, in async_setup_locked
await self.async_setup(hass, integration=integration)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 672, in async_setup
await self.__async_setup_with_context(hass, integration)
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 761, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File “/usr/src/homeassistant/homeassistant/components/google_generative_ai_conversation/init.py”, line 165, in async_setup_entry
2025-10-21 12:22:04.319 ERROR (Thread-7) [pychromecast.socket_client] [Master bedroom speaker(73ed4afe-cd6b-91d7-9c55-412ca810bdc6.local.):8009] Failed to connect to service MDNSServiceInfo(name=‘Google-Home-73ed4afecd6b91d79c55412ca810bdc6._googlecast._tcp.local.’), retrying in 5.0s
2025-10-21 12:22:04.381 ERROR (Thread-10) [pychromecast.socket_client] [Lounge speaker(f560494c-11ea-72c3-11a8-8cc004c91d66.local.):8009] Failed to connect to service MDNSServiceInfo(name=‘Google-Home-f560494c11ea72c311a88cc004c91d66._googlecast._tcp.local.’), retrying in 5.0s
2025-10-21 12:22:04.381 ERROR (Thread-8) [pychromecast.socket_client] [Tallons Room speaker(8f867fab-80c5-1746-d28b-e1d519fd8933.local.):8009] Failed to connect to service MDNSServiceInfo(name=‘Google-Nest-Mini-8f867fab80c51746d28be1d519fd8933._googlecast._tcp.local.’), retrying in 5.0s
2025-10-21 12:22:05.485 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template<template=(
{%- endfor %}) renders=12>
TypeError: ‘NoneType’ object is not iterable
homeassistant.exceptions.TemplateError: TypeError: ‘NoneType’ object is not iterable
2025-10-21 12:22:06.753 ERROR (MainThread) [custom_components.frigate.api] Error fetching information from http://ccab4aaf-frigate:5000/api/stats: Cannot connect to host ccab4aaf-frigate:5000 ssl:False [Timeout while contacting DNS servers]
