This might be more of a general notification query with home assistant, currently with our konnected system and other notifications.
I’m using the ‘notify.notify’ to send an alert which pops up on our phone.
Question I have is, is there a way to send an sms or a vibration alert to your phone, something that has to be dismissed?
Reason I ask, in the example with konnected, if the alarm goes off, or if home assistant detects the garage door open (via ismartgate) I’d like for it to send a notification that the user has to ‘dismiss’ or acknowledge.
Rather than have the alert just sit on the phone that could be missed.
For our security alerts we use (depending on circumstances):
HA Android official application with a notification channel configured to bypass DnD settings and a horrifically loud alert tone.
Pushover messages using the priority setting to bypass DnD with a repeating sound every 60 seconds for 5 minutes or until acknowledged in the Pushover app.
For repeating alerts you can use the while construct in the automation if you prefer. I switched our garage door from an Alert to a repeating notification to keep the code more centralised and easier to reload without a restart if changed:
# send notifications when open 15 minutes at 5 minute intervals until 30 minutes
repeat:
while:
- condition: state
entity_id: cover.garage_door
state: "open"
- condition: template
value_template: "{{ repeat.index <= 4 }}"
sequence:
- service: notify.mobile
title: "Security Alert"
message: "The Garage Door has been open for <b>{{ (15 + (repeat.index * 5)) }}</b> minutes."
i need to check this out, currently on a hauwei p30 pro as my primary phone / wife on iphone, so need to check this out. I believe with mine it only allows interruptions from specific callers / messages ie “favourites only” , not app specific but will need to check more detail.
I also need to check that ‘alert’ item as mentioned as I really want something to appear and notify us thats alarming / makes us take notice so we have to dismiss the event, if / when the alarm is triggered.
