I have a number of views setup on my install and the name of the HA location isnt being respected, Instead of the correct name its simply showing Home Assistant. If I remove the views it shows the correct name which I set in configuation.yaml. Is this a bug? below is my config.
homeassistant:
# Name of the location where Home Assistant is running
name: Name of my install
