Home Assistant Locks Up on Loss of Network (Ethernet)
I am experiencing a semi-frequent issue at this time that has me wanting to see if there is a solution. Rather simple system at this time. 8 Zigbee devices.
Home Assistant on a Pi 4 8GB inside the 7inch Touch Screen. Powered from a 12V with the Pi receiving power from an injection point not USB.
I’ve been experiencing issues with my Peplink Router locking up which causes Home Assistant to lockup. This is a test environment until I can install this setup in a permanent location that absolutely must run with extremely limited user maintenance.
The only way I can seem to recover is pulling power and rebooting the system. Only network issues cause this to occur and it can be simulated by unplugging the Ethernet cable. It will never recover.
This error shows up multiple times in the log in red around the time I expect the network issues are occurring. Is this causing it to lockup so bad that I have to power cycle?
2025-11-11 05:39:04.676 ERROR (MainThread) [supervisor.store] Could not reload repository d5369777 due to StoreJobError(“‘GitRepo.pull’ blocked from execution, no supervisor internet connection”)
