Hello friends,
I am new to Home Assistant. Everything was working fine until my ISP had to do a hard refresh for some reason causing my Raspberry Pi 3 to disconnect from the internet. Once my internet was fixed, I noticed I started getting errors with my Home Assistant.
The errors that I am getting are:
Sat Nov 17 2018 18:37:25 GMT-0600 (Central Standard Time)
Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 384, in _make_request
six.raise_from(e, None)
File "<string>", line 2, in raise_from
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 380, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.6/http/client.py", line 1331, in getresponse
response.begin()
File "/usr/local/lib/python3.6/http/client.py", line 297, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.6/http/client.py", line 258, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.6/socket.py", line 586, in readinto
return self._sock.recv_into(b)
socket.timeout: timed out
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 638, in urlopen
_stacktrace=sys.exc_info()[2])
File "/usr/local/lib/python3.6/site-packages/urllib3/util/retry.py", line 367, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.6/site-packages/urllib3/packages/six.py", line 686, in reraise
raise value
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 600, in urlopen
chunked=chunked)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 386, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.6/site-packages/urllib3/connectionpool.py", line 306, in _raise_timeout
raise ReadTimeoutError(self, url, "Read timed out. (read timeout=%s)" % timeout_value)
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='192.168.1.1', port=80): Read timed out. (read timeout=10)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 692, in async_device_tracker_scan
found_devices = await scanner.async_scan_devices()
File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 56, in run
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/linksys_smart.py", line 44, in scan_devices
self._update_info()
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/linksys_smart.py", line 57, in _update_info
response = self._make_request()
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/device_tracker/linksys_smart.py", line 105, in _make_request
json=data)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 116, in post
return request('post', url, data=data, json=json, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 524, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/sessions.py", line 637, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.6/site-packages/requests/adapters.py", line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.1.1', port=80): Read timed out. (read timeout=10)
What can be causing this problem and how can I fix this?
Marxcel
