Home-assistant.log grows and grows, please can you help me?!?!?
Hi everyone,
maybe someone can help me.
My log file is growing faster than average.
Yesterday it was at 1GB. Today I rebooted the host about 2 hours ago.
The log file is already 66MB and continues to grow.
What could be the reason?
Thanks in advance.
###################################################### LOG
logger:
  default: error
  logs:
    homeassistant.core: error
    homeassistant.components.python_script: error
    homeassistant.components.template: error
    # Rain Bird
    pyrainbird: error
    homeassistant.components.pyrainbird: error
    homeassistant.components.rainbird: error
    homeassistant.components.sensor: error
###################################################### History
history:
  include:
    entities:
      - sensor.luxtronik_id_web_wp_bz_akt
      - sensor.luxtronik_id_web_analogout2
      - luxtronik.id_web_temperatur_tvl
      - luxtronik.id_web_temperatur_tss
      - luxtronik.id_web_temperatur_tsk
      - luxtronik.id_web_temperatur_trl
      - luxtronik.id_web_temperatur_tbw
      - luxtronik.id_web_temperatur_ta
      - luxtronik.id_web_sollwert_trl_hz
      - luxtronik.id_web_mitteltemperatur
      - luxtronik.id_web_einst_bws_akt
      - luxtronik.id_web_vd1out
      - luxtronik.id_web_slpout
      - sensor.solarthermie
      - sensor.warmwasser
      - sensor.heizen
      - sensor.evu
      - sensor.bad_temperature
      - sensor.ble_temperature_a4c13898aecb
      - sensor.bme280_temperature
      - sensor.k1_temperature
      - sensor.k2_temperature
      - sensor.schlafzimmer_temperature
      - sensor.shellyswitch25_ba7900_device_temperature
      - sensor.shellyswitch25_ba854b_device_temperature
#####################################################  Recorder
recorder:
  db_url: mysql://xxx_user:[email protected]:3306/home_assistant?charset=utf8
You should search the reason in the file itself - just open it and check, which errors you are getting and eliminate them.
If all log levels are set to error : obviously errors.
Look at the errors and fix them.
