I’ve owned a iSmartAlarm system for over 5 years, it’s worked well until early this year when iSmartAlarm went bankrupt rendering my security system’s functionality to being a paperweight. I’ve been researching to buy another system, however I’m not keen to invest in another solution and becoming beholden another cloud solution that will inevitably go bust at some point.
Anyway below is a breakdown of my new alarm system using Home Assistant with a Xiaomi Aqara Gateway and Sensors. I will not go through how to connect any devices\integrations, but i will share the code I used to for Home Assistant to mimic the behaviours of the iSmartAlarm system including countdown warnings etc…
Let me know if you have any questions or feedback
Home Assistant Code for the Manual Alarm:
alarm_control_panel:
- platform: manual
code: 0000
code_arm_required: false # Don't require the code to arm the alarm
disarm_after_trigger: false # Arm again after triggering
arming_time: 300 # Delay from arming and becoming armed, eg. to leave the house.
delay_time: 120 # Allow time to disarm the alarm before it triggers, eg. when arriving home
trigger_time: 600 # Amount of time the alarm is triggered for
disarmed:
trigger_time: 0 # Ensure the alarm can never be directly triggered when disarmed
armed_home:
arming_time: 0 # Leave no delay between arming -> armed
delay_time: 0 # Leave no delay between pending -> triggered
Xiaomi Gateway Siren and Countdown Audio:
Note: these are required as the Xiaomi gateway alarms/ringtones only run for a few seconds. These scripts allow the countdown warning (when arming) and the alarm (when security system is triggered) to play continously when activated.
script:
security_alarm_loop_1:
sequence:
- service: script.turn_off
entity_id:
- script.security_countdown_loop_1
- script.security_countdown_loop_2
- service: xiaomi_aqara.play_ringtone
gw_mac: f0b429ccxxxx
ringtone_id: 2
ringtone_vol: 100
entity_id: script.security_alarm_loop_2
- delay: "00:00:6"
- service: script.turn_on
security_alarm_loop_2:
sequence:
entity_id:
ringtone_id: 1
ringtone_vol: 100
entity_id: script.security_alarm_loop_1
- delay: "00:00:10"
security_countdown_loop_1:
sequence:
entity_id: script.security_countdown_loop_2
ringtone_id: 29
ringtone_vol: 10
- delay: "00:00:15"
security_countdown_loop_2:
sequence:
entity_id: script.security_countdown_loop_1
ringtone_id: 29
ringtone_vol: 10
- delay: "00:00:15"
security_stop_loop_sounds:
alias: Stop Security Sound Scripts on Gateway
sequence:
entity_id:
- script.security_alarm_loop_1
- script.security_alarm_loop_2
- service: xiaomi_aqara.stop_ringtone
Automation Events for Alarm Status:
These include automations for what happens when:
- Home Security is Disarmed
- Home Security is in Arming State (i.e. play countdown warning sound)
- Home Security is in Armed State
- Event has occurred whilst Home Security is in Armed State
- Home Security is in Pending State (i.e. play countdown warning sound)
- Home Security is in Triggered State (i.e. play the Alarm Siren)
You can add triggers, actions and notifications as you require
automation:
- alias: SECURITY Disarmed State
- platform: state
entity_id: alarm_control_panel.home_security
to: "disarmed"
- service: media_player.volume_set
volume_level: 0.6
entity_id: media_player.nest_hub_max
- service: tts.google_translate_say
message: 'Security System has been Disarmed'
- service: script.security_stop_loop_sounds
- alias: SECURITY Arming State
- platform: state
to: "arming"
volume_level: 0.6
message: 'Security System is Arming, you have 5 minutes'
- service: script.security_countdown_loop_1
- alias: SECURITY Armed_Away State
- platform: state
to: "armed_away"
volume_level: 0.6
message: 'Security System is now armed'
- alias: SECURITY Triggered by the Sensors whilst Armed_Away
- platform: state
entity_id: binary_sensor.door_window_sensor_158d0001b7xxxx #front door
to: "on"
- platform: state
entity_id: binary_sensor.door_window_sensor_158d0001b7xxxx #rear sliding door
to: "on"
condition:
- condition: state
state: armed_away
- service: alarm_control_panel.alarm_trigger
- alias: SECURITY Pending State
- platform: state
to: "pending"
volume_level: 0.6
message: 'Security is armed, alarm countdown commencing'
- alias: SECURITY Triggered State
- platform: state
to: "triggered"
- service: script.security_alarm_loop_1
BONUS Content:
Use a Xiaomi/Aqara button to Arm and Disarm the alarm system
automation:
- alias: AQARA Button press
platform: event
event_type: xiaomi_aqara.click
event_data:
entity_id: binary_sensor.switch_158d00010axxxx
click_type: single
- service: >
{% if is_state("alarm_control_panel.home_security", "disarmed") %}
alarm_control_panel.alarm_arm_away
{% else %}
alarm_control_panel.alarm_disarm
{% endif %}
code: 0000
- alias: AQARA Button LONG press
platform: event
event_data:
click_type: long_click_press
- service: >
{% else %}
{% endif %}
code: 0000
Lovelace YAML to display your cameras in the main view only when the Home Security is in any other state outside of “disarmed”. NOTE: To save space on the UI, I use BlueIris to create a single camera that combines all my security cameras into a single feed
- id: main-tab # title: Main
title: Main
badges:
cards:
- id: home-cameras-when-armed
type: conditional
conditions:
- entity: alarm_control_panel.home_security
state_not: disarmed
card:
type: picture-entity
title: Home Cameras
entity: camera.all_cameras
camera_image: camera.all_cameras
show_info: false
#tap_action: dialog
show_name: false
show_state: false
