Hi all,
I have reinstall a few week ago from zero, home assistant OS on mi pri3b+ and recunfigured it from skratch. Now after some power failure I’am not able to reach the Home Assistant default page on 8123 port anymore. This is the error in core logs.
2022-10-13 22:51:28.538 WARNING (MainThread) [homeassistant.components.hassio] Can’t read Supervisor data:
2022-10-13 22:52:22.663 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /refresh_updates request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:52:22.679 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:52:22.684 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:52:22.689 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:52:22.694 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:53:42.706 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /refresh_updates request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:53:42.733 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:53:42.737 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:53:42.741 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:53:42.746 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:55:02.759 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /refresh_updates request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:55:02.778 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:55:02.784 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:55:02.789 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:55:02.793 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:56:22.807 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /refresh_updates request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:56:22.824 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:56:22.829 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:56:22.834 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:56:22.838 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:56:28.569 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:56:28.576 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /host/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:56:28.580 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /store request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:56:28.583 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:56:28.593 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
2022-10-13 22:56:28.598 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Network unreachable]
I tried everything but I’am not able to solve this problem, in Supervisor logs all things seems to be ok:
22-10-13 21:09:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-10-13 21:09:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-10-13 21:09:29 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-10-13 21:09:29 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-10-13 21:09:29 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-10-13 21:09:29 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-10-13 21:09:29 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-10-13 21:38:59 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-10-13 21:38:59 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-10-13 21:44:28 INFO (MainThread) [supervisor.host.info] Updating local host information
22-10-13 21:44:30 INFO (MainThread) [supervisor.host.services] Updating service information
22-10-13 21:44:30 INFO (MainThread) [supervisor.host.network] Updating local network information
22-10-13 21:44:30 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-10-13 21:44:30 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-10-13 22:09:29 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-10-13 22:09:29 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-10-13 22:09:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
22-10-13 22:09:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
22-10-13 22:09:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
22-10-13 22:09:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-10-13 22:09:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
22-10-13 22:09:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-10-13 22:09:30 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-10-13 22:09:30 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-10-13 22:09:30 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-10-13 22:09:31 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-10-13 22:09:31 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-10-13 22:09:31 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-10-13 22:10:47 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-10-13 22:11:20 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - sabeechen/hassio-google-drive-backup: Automatically create and sync Home Assistant backups into Google Drive repository
22-10-13 22:11:20 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - esphome/home-assistant-addon: ESPHome Home Assistant Add-on repository
22-10-13 22:11:20 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - home-assistant/addons: ➕ Docker add-ons for Home Assistant repository
22-10-13 22:11:20 INFO (MainThread) [supervisor.store.git] Update add-on GitHub - hassio-addons/repository: Home Assistant Community Add-ons repository
22-10-13 22:11:24 INFO (MainThread) [supervisor.store] Loading add-ons from store: 68 all - 0 new - 0 remove
22-10-13 22:37:47 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_ssh
22-10-13 22:37:47 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_ssh
22-10-13 22:37:47 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from core_ssh
22-10-13 22:38:03 INFO (MainThread) [supervisor.api.middleware.security] /core/logs access from core_ssh
22-10-13 22:38:09 INFO (MainThread) [supervisor.api.middleware.security] /core/logs access from core_ssh
22-10-13 22:38:44 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
22-10-13 22:39:00 INFO (MainThread) [supervisor.api.middleware.security] /addons access from core_ssh
22-10-13 22:39:01 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-10-13 22:39:01 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-10-13 22:40:11 INFO (MainThread) [supervisor.api.middleware.security] /addons access from core_ssh
22-10-13 22:40:22 INFO (MainThread) [supervisor.api.middleware.security] /addons/core_duckdns/restart access from core_ssh
22-10-13 22:40:22 INFO (SyncWorker_6) [supervisor.docker.interface] Stopping addon_core_duckdns application
22-10-13 22:40:29 INFO (SyncWorker_6) [supervisor.docker.interface] Cleaning addon_core_duckdns application
22-10-13 22:40:33 INFO (SyncWorker_5) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-duckdns with version 1.15.0
22-10-13 22:41:10 INFO (MainThread) [supervisor.api.middleware.security] /addons/core_duckdns/logs access from core_ssh
22-10-13 22:41:17 INFO (MainThread) [supervisor.api.middleware.security] /addons/core_duckdns/logs access from core_ssh
22-10-13 22:42:00 INFO (MainThread) [supervisor.api.middleware.security] /addons/core_duckdns/logs access from core_ssh
22-10-13 22:43:18 INFO (MainThread) [supervisor.api.middleware.security] /addons/core_duckdns/rebuild access from core_ssh
22-10-13 22:43:18 ERROR (MainThread) [supervisor.addons] Can’t rebuild a image based add-on
22-10-13 22:47:44 INFO (MainThread) [supervisor.api.middleware.security] /addons/core_duckdns/restart access from core_ssh
22-10-13 22:47:44 INFO (SyncWorker_1) [supervisor.docker.interface] Stopping addon_core_duckdns application
22-10-13 22:47:49 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning addon_core_duckdns application
22-10-13 22:47:49 ERROR (MainThread) [supervisor.utils.dbus] D-Bus method org.freedesktop.DBus.Properties.call_get_all not exists!
22-10-13 22:47:49 WARNING (MainThread) [supervisor.dbus.network] Can’t process /org/freedesktop/NetworkManager/Devices/29:
22-10-13 22:47:49 WARNING (MainThread) [supervisor.dbus.network] Can’t process /org/freedesktop/NetworkManager/Devices/30:
22-10-13 22:47:51 INFO (SyncWorker_6) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-duckdns with version 1.15.0
22-10-13 22:51:54 INFO (MainThread) [supervisor.api.middleware.security] /addons/core_duckdns/logs access from core_ssh
22-10-13 22:52:04 INFO (MainThread) [supervisor.api.middleware.security] /addons/core_duckdns/logs access from core_ssh
22-10-13 22:52:44 INFO (MainThread) [supervisor.api.middleware.security] /core/logs access from core_ssh
22-10-13 22:56:57 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_ssh
22-10-13 22:58:34 INFO (MainThread) [supervisor.api.middleware.security] /core/update access from core_ssh
22-10-13 22:58:34 ERROR (MainThread) [supervisor.utils] Can’t execute update while a task is in progress
22-10-13 22:58:40 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/update access from core_ssh
22-10-13 22:59:12 INFO (MainThread) [supervisor.api.middleware.security] /docker/info access from core_ssh
22-10-13 22:59:59 INFO (MainThread) [supervisor.api.middleware.security] /core/update access from core_ssh
22-10-13 22:59:59 ERROR (MainThread) [supervisor.utils] Can’t execute update while a task is in progress
22-10-13 23:00:03 INFO (MainThread) [supervisor.api.middleware.security] /core/logs access from core_ssh
22-10-13 23:03:18 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/logs access from core_ssh
How can I solve this porblem? Can someone help me?
