Been struggling to get this working with NGINIX – ending up with 404 or 502. All the documentation I’ve found refers to a setup with foo.host.com or just host.com (and upgrading http->https in the proxy process) and I’m trying to get this working using https://host.com/hass (in my case.) Got Portainer, OpenZWave, etc all running in dockers and reverse-proxied without issue but can’t get this working to save my life.
I followed all the configs, documentation and suggestions I could find via search but none really applied to me. It always ends up with the http errors mentioned above because while the “index” file loads, /frontend/ and /static/ directories end up being a 404 (so it can’t find them) or I get the infamous bad gateway.
Has anyone been able to get this working in line with what I’m trying to do? I have it running as https://host.com:8123/ without issue for a year now, never had any issues but I’d like it hide it behind https://host.com/hass/ instead so I can drop the port-forwarding, etc I currently have in place. I recently just upgraded Home Assistant to run in a docker (don’t know how I lived without this to be honest) and it works perfectly fine with my existing config.
