hi, i have a problem when i try to update home assistant with the command:
sudo hassbian-config upgrade homeassistant
this is the error:
pi@hassbian:~ $ sudo hassbian-config upgrade homeassistant
Generating system information…
Home Assistant: 0.106.5
Home Assistant Python: 3.7.3
hassbian-config: 0.13.1
Linux hassbian 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l GNU/Linux
Suite: Home Assistant
Installed: true
Contributed to the project by Lindqvist https://github.com/Landrash
Installs the base homeassistant package onto this system.
Checking current version
Setting correct permissions
Upgrading Home Assistant
Changing to homeassistant user…
Changing to Home Assistant venv…
Updating Python dependencies…
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already up-to-date: pip in /srv/homeassistant/lib/python3.7/site-packages (20.0.2)
Collecting setuptools
Downloading setuptools-46.0.0-py3-none-any.whl (582 kB)
Installing collected packages: setuptools
Attempting uninstall: setuptools
Found existing installation: setuptools 45.2.0
Uninstalling setuptools-45.2.0:
Successfully uninstalled setuptools-45.2.0
Successfully installed setuptools-46.0.0
Requirement already up-to-date: wheel in /srv/homeassistant/lib/python3.7/site-packages (0.34.2)
Installing Python packages…
ERROR: Could not find a version that satisfies the requirement homeassistant== (from versions: 0.7.0rc1, 0.7.0, 0.7.0.1, 0.7.1, 0.7.2, 0.7.3, 0.7.4, 0.7.5, 0.7.6, 0.7.7, 0.8.0, 0.9.0, 0.9.1, 0.10.0, 0.10.1, 0.11.0, 0.11.1, 0.12.0, 0.13.0, 0.13.1, 0.14.0, 0.14.1, 0.14.2, 0.15.0, 0.16.0, 0.16.1, 0.17.0, 0.17.1, 0.17.2, 0.17.3, 0.18.2, 0.19, 0.19.1, 0.19.2, 0.19.3, 0.19.4, 0.20.0, 0.20.1, 0.20.2, 0.20.3, 0.21.0, 0.21.1, 0.21.2, 0.22.0, 0.22.1, 0.23.0, 0.23.1, 0.24.0, 0.24.1, 0.25.0, 0.25.1, 0.25.2, 0.26.0, 0.26.1, 0.26.2, 0.26.3, 0.27.0, 0.27.1, 0.27.2, 0.28.0, 0.28.1, 0.28.2, 0.29.0, 0.29.1, 0.29.2, 0.29.3, 0.29.4, 0.29.5, 0.29.6, 0.29.7, 0.30.0, 0.30.1, 0.30.2, 0.31.0, 0.31.1, 0.32.0, 0.32.1, 0.32.2, 0.32.3, 0.32.4, 0.33.0, 0.33.1, 0.33.2, 0.33.3, 0.33.4, 0.34.0, 0.34.1, 0.34.2, 0.34.3, 0.34.4, 0.34.5, 0.35.0, 0.35.1, 0.35.2, 0.35.3, 0.36.0, 0.36.1, 0.37.0, 0.37.1, 0.38.0, 0.38.1, 0.38.2, 0.38.3, 0.38.4, 0.39.0, 0.39.1, 0.39.2, 0.39.3, 0.40.0, 0.40.1, 0.40.2, 0.41.0, 0.42.0, 0.42.1, 0.42.2, 0.42.3, 0.42.4, 0.43.0, 0.43.1, 0.43.2, 0.44.0, 0.44.1, 0.45.0, 0.45.1, 0.46.0, 0.46.1, 0.47.0, 0.47.1, 0.48.0, 0.48.1, 0.49.0, 0.49.1, 0.50.1, 0.50.2, 0.51.0, 0.51.1, 0.51.2, 0.52.0, 0.52.1, 0.53.0, 0.53.1, 0.54.0, 0.55.0, 0.55.1, 0.56.0, 0.56.1, 0.56.2, 0.57.0, 0.57.1, 0.57.2, 0.57.3, 0.58.0, 0.58.1, 0.59.0, 0.59.1, 0.59.2, 0.60.0, 0.60.1, 0.61.0, 0.61.1, 0.62.0, 0.62.1, 0.63.0, 0.63.1, 0.63.2, 0.63.3, 0.64.0, 0.64.1, 0.64.2, 0.64.3, 0.64.4b0, 0.65.0, 0.65.1, 0.65.2, 0.65.3, 0.65.4, 0.65.5, 0.65.6, 0.66.0b0, 0.66.0b1, 0.66.0b2, 0.66.0b3, 0.66.0, 0.66.1b0, 0.66.1, 0.67.0b0, 0.67.0b1, 0.67.0, 0.67.1, 0.68.0b0, 0.68.0b1, 0.68.0b2, 0.68.0, 0.68.1, 0.69.0b0, 0.69.0b1, 0.69.0b2, 0.69.0b3, 0.69.0, 0.69.1, 0.70.0b0, 0.70.0b1, 0.70.0b2, 0.70.0b3, 0.70.0b4, 0.70.0b5, 0.70.0b6, 0.70.0b7, 0.70.0, 0.70.1, 0.71.0b0, 0.71.0, 0.72.0b0, 0.72.0b1, 0.72.0b2, 0.72.0b4, 0.72.0b5, 0.72.0b6, 0.72.0b7, 0.72.0b8, 0.72.0b9, 0.72.0, 0.72.1, 0.73.0b0, 0.73.0b1, 0.73.0b2, 0.73.0b3, 0.73.0b4, 0.73.0b5, 0.73.0b6, 0.73.0, 0.73.1, 0.73.2, 0.74.0b0, 0.74.0b2, 0.74.0b3, 0.74.0b4, 0.74.0, 0.74.1, 0.74.2, 0.75.0b0, 0.75.0b1, 0.75.0, 0.75.1, 0.75.2, 0.75.3, 0.76.0b0, 0.76.0b1, 0.76.0b2, 0.76.0b3, 0.76.0b4, 0.76.0b5, 0.76.0, 0.76.1, 0.76.2, 0.77.0b0, 0.77.0b1, 0.77.0b2, 0.77.0b3, 0.77.0b4, 0.77.0, 0.77.1, 0.77.2, 0.77.3, 0.78.0b0, 0.78.0b1, 0.78.0b2, 0.78.0b3, 0.78.0, 0.78.1, 0.78.2, 0.78.3, 0.79.0b0, 0.79.0b1, 0.79.0b2, 0.79.0b3, 0.79.0, 0.79.1, 0.79.2, 0.79.3, 0.80.0b0, 0.80.0b1, 0.80.0b2, 0.80.0b3, 0.80.0b4, 0.80.0b5, 0.80.0, 0.80.1, 0.80.2, 0.80.3, 0.81.0b0, 0.81.0b1, 0.81.0b2, 0.81.0, 0.81.1, 0.81.2, 0.81.3, 0.81.4, 0.81.5, 0.81.6, 0.82.0b0, 0.82.0b1, 0.82.0b2, 0.82.0b3, 0.82.0b4, 0.82.0, 0.82.1, 0.83.0b0, 0.83.0b1, 0.83.0b3, 0.83.0, 0.83.1, 0.83.2, 0.83.3, 0.84.0b0, 0.84.0b1, 0.84.0b2, 0.84.0b3, 0.84.0b4, 0.84.0, 0.84.1, 0.84.2, 0.84.3, 0.84.4, 0.84.5, 0.84.6, 0.85.0b0, 0.85.0b1, 0.85.0, 0.85.1, 0.86.0b0, 0.86.0b1, 0.86.0b2, 0.86.0b3, 0.86.0, 0.86.1, 0.86.2, 0.86.3, 0.86.4, 0.87.0b0, 0.87.0b1, 0.87.0b2, 0.87.0b3, 0.87.0b4, 0.87.0b5, 0.87.0b6, 0.87.0, 0.87.1, 0.88.0b0, 0.88.0b1, 0.88.0b2, 0.88.0b3, 0.88.0b4, 0.88.0, 0.88.1, 0.88.2, 0.89.0b0, 0.89.0b1, 0.89.0b2, 0.89.0b3, 0.89.0, 0.89.1, 0.89.2, 0.90.0b0, 0.90.0b1, 0.90.0b2, 0.90.0b3, 0.90.0b4, 0.90.0b5, 0.90.0b6, 0.90.0b7, 0.90.0, 0.90.1, 0.90.2, 0.91.0b0, 0.91.0b1, 0.91.0b2, 0.91.0b3, 0.91.0b4, 0.91.0b5, 0.91.0, 0.91.1, 0.91.2, 0.91.3, 0.91.4, 0.92.0b0, 0.92.0b1, 0.92.0b2, 0.92.0b3, 0.92.0, 0.92.1, 0.92.2, 0.93.0b0, 0.93.0b1, 0.93.0b2, 0.93.0b4, 0.93.0, 0.93.1, 0.93.2, 0.94.0b0, 0.94.0b1, 0.94.0b2, 0.94.0b3, 0.94.0b4, 0.94.0b5, 0.94.0b6, 0.94.0b7, 0.94.0b8, 0.94.0, 0.94.1, 0.94.2, 0.94.3, 0.94.4, 0.95.0b0, 0.95.0b1, 0.95.0b2, 0.95.0b3, 0.95.0b4, 0.95.0, 0.95.1, 0.95.2, 0.95.3, 0.95.4, 0.96.0b0, 0.96.0b1, 0.96.0b2, 0.96.0b3, 0.96.0b4, 0.96.0, 0.96.1, 0.96.2, 0.96.3, 0.96.4, 0.96.5, 0.97.0b0, 0.97.0b1, 0.97.0b2, 0.97.0b3, 0.97.0, 0.97.1, 0.97.2, 0.98.0b0, 0.98.0b1, 0.98.0b2, 0.98.0, 0.98.1, 0.98.2, 0.98.3, 0.98.4, 0.98.5, 0.99.0b0, 0.99.0b1, 0.99.0b2, 0.99.0b3, 0.99.0b4, 0.99.0, 0.99.1, 0.99.2, 0.99.3, 0.100.0b0, 0.100.0b1, 0.100.0b2, 0.100.0b3, 0.100.0, 0.100.1, 0.100.2, 0.100.3, 0.101.0b0, 0.101.0b1, 0.101.0b2, 0.101.0b3, 0.101.0b4, 0.101.0, 0.101.1, 0.101.2, 0.101.3, 0.102.0b0, 0.102.0b1, 0.102.0b2, 0.102.0b3, 0.102.0, 0.102.1, 0.102.2, 0.102.3, 0.103.0b0, 0.103.0b1, 0.103.0, 0.103.1, 0.103.2, 0.103.3, 0.103.4, 0.103.5, 0.103.6, 0.104.0b0, 0.104.0b1, 0.104.0b2, 0.104.0b3, 0.104.0b4, 0.104.0b5, 0.104.0, 0.104.1, 0.104.2, 0.104.3, 0.105.0b0, 0.105.0b1, 0.105.0b2, 0.105.0b3, 0.105.0b4, 0.105.0b5, 0.105.0b6, 0.105.0b7, 0.105.0, 0.105.1, 0.105.2, 0.105.3, 0.105.4, 0.105.5, 0.106.0b0, 0.106.0b1, 0.106.0b2, 0.106.0b4, 0.106.0b5, 0.106.0, 0.106.1, 0.106.2, 0.106.3, 0.106.4, 0.106.5, 0.106.6, 0.107.0b0)
ERROR: No matching distribution found for homeassistant==
Deactivating virtualenv…
how can i solve?
