Home Assistant. No Web Interface, High CPU Usage. Can log in but get error loading GUI as soon as 2FA code entered
How can I begin to debug this through the CLI?
delete your database and restart HA
depending on your install
in linux i would do a service hass status (i called my service hass)
and see what messages show up.
bloody hell not again. yeah likely the case. will try when home. ta
it seems that ssh access has been disturbed too so will have to do through cli. is it possible to delete db through cli?
Appears to be a malformed DB again. No idea how to fix this without SSH access
I already tried core rebuild but did not make a difference. AFAIK this problem has been solved as HA should archive the DB and create new one but this does not seem to be the case here
