Home assistant node red not properly working
Problem with Home Assistant node red.
I use this flow to read my Huawei Sun2000 modbus register. It has been working without problem for a while. Now I can’t get any debug messages, no sensor node updates and it is not possible to manually run the flow. Both inject node left part and debug node right part seems to be disabled. I still get sensor updates in my Home Assistant Lovelace but not able to add any new sensors. Has anyone had these problems and maybee a solution?
Make sure you do a full deploy and then look for messages in the addons log page.
I always do the full deploy. The problem is related to manually run the flow and sensor and debug info. Node red sensors are updated in lovelace. I found this in the addon log:
29 Jun 08:12:19 - [info] [mqtt-broker:d5c2659b.267728] Connection failed to broker: mqtt://192.168.21.10:1883
Try to restart the addon
Done that ten times. Also tried to back to older core version without success.
Have you tried restarting the entire host also?
Ye, several times.
Check if any palettes need an update.
Did you manage to solve this problem, unfortunately I have exactly the same issue. I haven’t used node-red recently, so I’ve had a problem for some time. Rolling back to the previous version didn’t help.
Update all the palets. Ive gotten this isseu a couple of days ago. So everything needed to be updated. After that, just reboot the add-on.
I’ve done this before (HA nodes have been upgraded) and restarted node-red and even the whole HA multiple times, but the problem persists.
Hi! I have figured out is’s related to if I have any unused nodes in NR.
