After trying to setup casting to a Nest Hub I’m unable to access home assistant anymore, not from inside and outside… The message: No auth providers returned. Unable to finish login.
I must have made a mistake with the trusted network setup, but how can I recover from this? Help please!
Thank you
Edit: I’m using Cloudflare to access from outside, but as said locally doesn’t work either
