Home Assistant not found when trying to add HA in HomeKit
I’m trying to setup the newly added native HomeKit support in Home Assistant. I added this in configuration.yaml
homekit:
  auto_start: True
And it shows a code for HomeKit Setup in HA’s front end/dashboard.
But it’s not found when I try to add Home Assistant’s bridge to the iOS Home app.
In the Home app I go Add Accessory > Don’t Have A Code Or Cant Scan > Enter (manual) Code, then enter the code shown in Home Assistant.
But after adding the code it doesn’t show any new accessories that can be added (Home Assistant’s bridge).
Any idea why it doesn’t show up in Home.app, or what I can check or try to make it show up/work properly?
Same problem here.
