Home Assistant not knowing the states of switches/plugs after startup
I’m having an issue where Home Assistant doesn’t know about the state of some of my tasmota plugs or switches when it reboots. I’ve tried several things I’ve found in searching the forums and elsewhere. Is there something wrong with my configuration?
Here’s one of the plugs that I’m having trouble with. It is supposed to turn off and back on power to the cable modem if the Internet goes down, so it should pretty much always be on.
  - platform: mqtt
    command_topic: "cmnd/TeckinModem/POWER"
    state_topic: "stat/TeckinModem/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
    retain: false
I also ran PowerRetain 1 in the plug console
Here is the automation that I’ve added that is supposed to sync the states of my tasmota devices at startup.
- id: 'sync tasmota'
  alias: Tasmota Restore State at Startup
    platform: homeassistant
    event: start
  - service: mqtt.publish
      payload: ''
      topic: cmnd/sonoffs/state
When it does run, I do see the plug respond in its console, but it’s state doesn’t update in HA.
14:29:43 MQT: stat/TeckinModem/RESULT = {"Time":"2020-10-04T14:29:43","Uptime":"15T09:39:19","UptimeSec":1330759,"Vcc":3.447,"Heap":30,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":30,"MqttCount":5,"POWER":"ON","Wifi":{"AP":1,"SSId":"5m@77-273","BSSId":"F2:9F:C2:71:14:30","Channel":6,"RSSI":100,"Signal":-28,"LinkCount":3,"Downtime":"0T00:02:07"}}
Is there anything I’m doing wrong? I’m running hassio with HA 0.114.0, and the tasmota version of that particular plug is 8.1.0
i had te same problem. in my configuration. yaml i put
retain: false
and on the sonoffs i did:
switchretain off
buttonretain on
buttonretain off
powerretain on
and it seems ok now, i had the info from here: https://www.youtube.com/watch?v=31IyfM1gygo&t=472s
the /RESULT topic response is in JSON. You need to extract just the POWER setting from the list, and use the /RESULT topic (ie - not /POWER topic which is just for the command, not the state ):
    state_topic: "stat/TeckinModem/RESULT"
    state_value_template: "{{value_json.POWER}}"
Awesome! I think that did it. I had to change it to
Thanks!
ah of course, my mistake. state_value_template is for mqtt lights, value_template is for switches
