Hi
I’ve been facing issues with my home assistant not starting / starting and then stopping after i started using the google generative ai integration (not sure if it’s causally linked).
I bit the bullet after no logs were being generated and decided to do a fresh install. I’ve tried both an USB drive and an SD card.
However, once i power up / connect the home assistant via a lan cable, nothing seems to work - i’m not able to reach the home assistant page.
Looking at the sd card - i can see the hassio-data partition, however, there is nothing in the the homeassistant folder (where you’d normally expect to see logs)
Port querying homeassistant, i can see that the IP address has resolved, but the port 8123 is not listening.
Has anyone faced something similar?
