Hi all,
as in subject today I updated Home Assistant to last version and it’s not working anymore… It is not the first time I update and I have never had any problems, I do not understand the reason for this tragedy this time.
These are errors I see in log
Logger: aiohttp.server
Source: /usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py:405
First occurred: 13:06:28 (1 occurrences)
Last logged: 13:06:28
Unhandled exception
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1191, in _sendfile_fallback
read = await self.run_in_executor(None, file.readinto, view)
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 514, in start
resp, reset = await task
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 460, in _handle_request
reset = await self.finish_response(request, resp, start_time)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 613, in finish_response
await prepare_meth(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_fileresponse.py", line 286, in prepare
return await self._sendfile(request, fobj, offset, count)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_fileresponse.py", line 99, in _sendfile
await loop.sendfile(transport, fobj, offset, count)
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1170, in sendfile
return await self._sendfile_fallback(transport, file,
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 1200, in _sendfile_fallback
await proto.restore()
File "/usr/local/lib/python3.10/asyncio/base_events.py", line 268, in restore
self._transport.resume_reading()
File "/usr/local/lib/python3.10/asyncio/sslproto.py", line 343, in resume_reading
self._ssl_protocol._transport.resume_reading()
AttributeError: 'NoneType' object has no attribute 'resume_reading'
Logger: homeassistant.util.package
Source: util/package.py:96
First occurred: 13:02:53 (2 occurrences)
Last logged: 13:07:53
Unable to install package adafruit-circuitpython-dht==3.7.0: error: subprocess-exited-with-error × python setup.py bdist_wheel did not run successfully. │ exit code: 1 ╰─> [15 lines of output] running bdist_wheel running build running build_py Compiling ws281x library... creating build creating build/lib.linux-aarch64-cpython-310 creating build/lib.linux-aarch64-cpython-310/rpi_ws281x copying rpi_ws281x/rpi_ws281x.py -> build/lib.linux-aarch64-cpython-310/rpi_ws281x copying rpi_ws281x/__init__.py -> build/lib.linux-aarch64-cpython-310/rpi_ws281x running build_ext building '_rpi_ws281x' extension creating build/temp.linux-aarch64-cpython-310 creating build/temp.linux-aarch64-cpython-310/lib gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -DTHREAD_STACK_SIZE=0x100000 -fPIC -I. -I/usr/local/include/python3.10 -c lib/dma.c -o build/temp.linux-aarch64-cpython-310/lib/dma.o error: command 'gcc' failed: No such file or directory [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. ERROR: Failed building wheel for rpi_ws281x error: subprocess-exited-with-error × python setup.py bdist_wheel did not run successfully. │ exit code: 1 ╰─> [15 lines of output] ****************************************************************************** * Setup can't determine the value of PAGE_SIZE on your system, so it will * default to 4096 which may not be correct. * * Please report this message and your operating system info to the package * maintainer listed in the README file. ****************************************************************************** running bdist_wheel running build running build_ext building 'sysv_ipc' extension creating build creating build/temp.linux-aarch64-cpython-310 gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/local/include/python3.10 -c common.c -o build/temp.linux-aarch64-cpython-310/common.o error: command 'gcc' failed: No such file or directory [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. ERROR: Failed building wheel for sysv_ipc error: subprocess-exited-with-error × Running setup.py install for sysv_ipc did not run successfully. │ exit code: 1 ╰─> [17 lines of output] ****************************************************************************** * Setup can't determine the value of PAGE_SIZE on your system, so it will * default to 4096 which may not be correct. * * Please report this message and your operating system info to the package * maintainer listed in the README file. ****************************************************************************** running install /usr/local/lib/python3.10/site-packages/setuptools/command/install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools. warnings.warn( running build running build_ext building 'sysv_ipc' extension creating build creating build/temp.linux-aarch64-cpython-310 gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fno-semantic-interposition -fno-builtin-malloc -fno-builtin-calloc -fno-builtin-realloc -fno-builtin-free -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/local/include/python3.10 -c common.c -o build/temp.linux-aarch64-cpython-310/common.o error: command 'gcc' failed: No such file or directory [end of output] note: This error originates from a subprocess, and is likely not a problem with pip. error: legacy-install-failure × Encountered error while trying to install package. ╰─> sysv_ipc note: This is an issue with the package mentioned above, not pip. hint: See above for output from the failure.
2022-07-19 12:57:15 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration rpi_gpio which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-07-19 12:57:15 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration dht which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-07-19 12:57:15 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration triones which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-07-19 12:57:15 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-07-19 12:57:21 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2022-07-19 12:57:23 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=70 from 2022-07-19 10:07:04.854427)
2022-07-19 12:58:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 12:59:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:00:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:01:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:02:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:02:53 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package adafruit-circuitpython-dht==3.7.0: error: subprocess-exited-with-error
│ exit code: 1
running bdist_wheel
running build
running build_py
creating build
running build_ext
[end of output]
│ exit code: 1
running bdist_wheel
running build
running build_ext
creating build
[end of output]
│ exit code: 1
running install
warnings.warn(
running build
running build_ext
creating build
[end of output]
╰─> sysv_ipc
2022-07-19 13:03:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:03:41 WARNING (MainThread) [homeassistant.bootstrap] Setup timed out for stage 2 - moving forward
2022-07-19 13:04:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:05:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:06:28 ERROR (MainThread) [aiohttp.server] Unhandled exception
2022-07-19 13:06:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:07:29 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:07:53 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package adafruit-circuitpython-dht==3.7.0: error: subprocess-exited-with-error
│ exit code: 1
running bdist_wheel
running build
running build_py
creating build
running build_ext
[end of output]
│ exit code: 1
running bdist_wheel
running build
running build_ext
creating build
[end of output]
│ exit code: 1
running install
warnings.warn(
running build
running build_ext
creating build
[end of output]
╰─> sysv_ipc
2022-07-19 13:08:30 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:09:30 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:10:30 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:11:30 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
2022-07-19 13:12:30 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
There is a way to rollback this update or to fix these problems?
Thanks in advance,
D.
