Hey guys, I’ve got some LED strips and desk tube lamps that support both RGB and a white light mode which is brighter and more pleasing to the eyes compared to RGB white. I am wanting to switch between these however HASS only seems to support RGB on these, even though another light I have which supports colour temperature (basically the same colour I’m trying to get except this supports change of colour temperature where as the others don’t), comes up with the slider.
I am using Tuya app to add the devices which works fine, but in home assistant it just doesn’t come up.
Even in developer tools in home assistant, I try to add to a script the mode color_mode: Brightness
Which is what I want as the colour mode. Normally for RGB it is color_mode: RGB
or something like that
Any help would be much appreciated. Even if I can get a script or something to work it’s just that I don’t want to have to go to the Tuya app every time I switch from RGB colours to the solid brighter light colour.
Note: these devices are apart of the Mirabella Genio range of that changes anything
Thanks guys.
