Hi all,
I’m in the process of shutting down my HomeMatic CCU2 in favout for RaspberryMatic. All seemed to be fine, I was able to manually port all my devices to RaspberryMatic. When using the “Homematic(IP) Local” Integration it also shows all my Devices in Home Assistant, unfortunately my Thermostats are not identified as such. I’m not getting the expected entities.
As an example, one thermostat shows in Home Assistant as “climate.hmip_etrv_000397098bcc0e” but I don’t see any entities for temperatur, etc.
Anyone seen the same and has a solution or hint?
