My home assistant supervised was running fine on a raspberry pi 4b.
Yesterday, I noticed that some entities were not available anymore and that the names on the side tab were strange, like they were variable names (eg: dev_tools instead of “Strumenti per sviluppatori” /“Developer Tools”).
The system was still, I was out of town for many days so once I noticed it as I came back I rebooted and now Is unreachable. I thought it was a space issue, since many videos were recorded in the meantime, but I deleted them and nothing changed, here is disk space:
/dev/root 29653M 25192M 3209M 89% /
devtmpfs 1759M 0M 1759M 0% /dev
tmpfs 1920M 0M 1920M 0% /dev/shm
tmpfs 1920M 9M 1911M 1% /run
tmpfs 5M 1M 5M 1% /run/lock
tmpfs 1920M 0M 1920M 0% /sys/fs/cgroup
/dev/mmcblk0p1 253M 50M 203M 20% /boot
tmpfs 384M 0M 384M 0% /run/user/1000
Logging into the raspberry and checking via ssh the status:
sudo systemctl status hassio-supervisor
I get:
● hassio-supervisor.service - Hass.io supervisor
Loaded: loaded (/etc/systemd/system/hassio-supervisor.service; enabled; vendor preset: enabled)
Active: inactive (dead)
giu 10 10:35:28 raspberrypi systemd[1]: Dependency failed for Hass.io supervisor.
giu 10 10:35:28 raspberrypi systemd[1]: hassio-supervisor.service: Job hassio-supervisor.service/start failed with result 'dependency'.
So i tried:
sudo journalctl -fu [email protected]
Which gets me:
giu 10 10:33:57 raspberrypi systemd[488]: [email protected]: Failed to determine user credentials: No such process
giu 10 10:33:57 raspberrypi systemd[488]: [email protected]: Failed at step USER spawning /srv/homeassistant/bin/hass: No such process
giu 10 10:33:57 raspberrypi systemd[1]: Started Home Assistant.
giu 10 10:33:57 raspberrypi systemd[1]: [email protected]: Main process exited, code=exited, status=217/USER
giu 10 10:33:57 raspberrypi systemd[1]: [email protected]: Failed with result 'exit-code'.
So guessing it’s something with the used, I noticed that the system:
sudo nano /etc/systemd/system/[email protected]
Is:
[Unit]
Description=Home Assistant
After=network-online.target
[Service]
Type=simple
User=%i
ExecStart=/srv/homeassistant/bin/hass -c "/home/homeassistant/.homeassistant"
[Install]
WantedBy=multi-user.target
Is that user normal? I expected “homeassistant”, but by trying:
id homeassistant
It does not exist. Can I fix it manually?
